Old 22-12-2009, 11:04 AM   #1 (permalink)
blademast3r's Avatar
Cool Help me build a new gaming system
Hey guys i need to buy a new gaming system for around 25k..(I am returning my old system which will fetch me around 5-7 k so effective budget = 32k)
Here are the features im looking for
Good enuf graphics card to play crysis at high specs arn 1024x768 res
2+ gb ram
arnd 250gb storage
19inch lcd
Go...
blademast3r is online now
Old 22-12-2009, 07:39 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Help me build a new gaming system
At ur budget AMD is the best
Here goes ur config:
Athlon II X4 620 2.6GHz @ 5.1k (The most VFM Quad core)
MSI 785GM-E51 @ 4.6k (AM3, DDR3 board)
2 GB Transcend/Kingston DDR3 1333 MHz ram @ 2.5k
500 GB Seagate SATA @ 2.4k
PowerColor HD4850 1GB GDDR3 @ 7.2k
LG DVD Writer @ 1k
Zebronics Krish Cabinet @ 1k
Gigabyte 80 Plus Active PFC 460W @ 2.2k
BenQ G2020HD 20" LCD Monitor @ 6.5k
Keyboard and Mouse: Generic @ 0.8k
Total price is around 33k. Street price will be lower. This system is the most VFM system at your budget and it will fulfill ur wish.
Cilus is offline
Old 22-12-2009, 09:38 PM   #3 (permalink)
Hey thanks for that jus checked this other thread and heres a list ive built pls lemme kno if its okay
Athlon II X2 240 2.8GHz
Biostar A785G
4GB DDR2 800MHz Transcend/Kingston
Zebronics Krish
Logitech Multimedia Keyboard/Mouse Combo
Seagate Barracuda 7200.12 500GB
Sapphire HD5770 1GB GDDR5
I wanna go for hd5770 as it supports dx11
but i hav a question will the athlon be a bottleneck?
Old 23-12-2009, 12:23 AM   #4 (permalink)
k heres a question
both come to the same price but which one better
1)quad core processor
2 gb ddr3 ram
hd 4850
2)dual core processor
4 gb ddr2 ram
hd 5750
which wud give me better performance and last longer.. will the dx11 in hd 5750 make a big diff?
Old 23-12-2009, 08:09 AM   #5 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
for how long are you going to keep this system... if you wont upgrade for 3-4 years then get the hd5750.... if you will upgrade in 1-2 years then you can go with the ati hd4000(dx10.1) series & get an athlon II X4
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 23-12-2009, 09:13 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by blademast3r View Post
k heres a question
2 gb ddr3 ram
hd 4850
4 gb ddr2 ram
hd 5750
the words in bold is better config...go for DDR3...DDR2 will fade away soon...
yes DX11 will make a difference in gaming...
Zangetsu is offline
Old 23-12-2009, 09:49 AM   #7 (permalink)
so ur saying 2db of ddr3 is better than 4gb of ddr2? does it make a significant diff in gaming?
Old 23-12-2009, 11:18 AM   #8 (permalink)
laborare est orare
Cilus's Avatar
No he is not saying that. The performance difference will be negligible if you use DDR3 ram. The thing is DDR2 ram is getting phased out and sooner they will be very hard to be available and price will be increased, like what happened to DDR ram a few years back.
Now the price of DDR2 and DDR3 is same. So go for DDR3. It is future proof solution. At your budget, it is hard to get 4GB ram right now. Go for 2 GB and latter upgrade it to 4 GB
And Quad core is always better option than a dual core now a days. It will give u performance boost in almost every application. Now current games are not optimized for multi cores, but in very near future they will be.
So go for the quad core Athlon II 620 2.6 GHz.
Cilus is offline
Old 25-12-2009, 02:00 AM   #9 (permalink)
k guys final opinion.. quad core or dual core?? decided the rest
Old 25-12-2009, 02:34 AM   #10 (permalink)
Courage to Know
Anubis's Avatar
Athlon II x4 620 is the way to go
If u don't upgrade for 3-4 years then ATI 5770 is way to go
But if u upgrade in 1-2 years ATI 4870 - 8.6k is better choice
ATI 5770 can't even beat ATI 4870 @ 8.6k
DX11 will take time to mature.
Anubis is offline
Old 25-12-2009, 11:17 AM   #11 (permalink)
4870 is better than the 5770 at a lower price?? seriously?? im not planning to make any upgrades for bout 4 years, which means ill need support to play future dx11 games.. so 5750 sounds good?
Old 25-12-2009, 11:54 AM   #12 (permalink)
Super Moderator
asingh's Avatar
Blade:
Will give you two arguements, you can make a choice:
Scenario 1:
The 4870 is a better bet right now for you. It will thrash the games on your 20" (except Crysis). Getting a 5xxx series card as of now is pretty useless. They are way too over priced due to low supply and high demand. There are not even 5 Dx11 games out as of now. It will take a while for these games to come out. And even then, how can you be so sure, the next or subsequent Dx11 game which comes out -- will be of your liking --- unless you play 'every' game which is released. The 4870 packs more punch then the 5770. 1.5-2 years down the line, when ever thing settle down (Fermi, Dx11, 5xxx, Dx11 games) you can swap cards.
Scenario 2:
The HD5770 is a good in one scenario. And probably the best here. Xfire. If you Xfire this card, it kicks the living daylight out of almost every card on this planet. If in the future you really plan to go Xfire, then only buy this card now. You are making a good investment this ways. Once you have more money, you can install another card. And believe me, you will have a whoooping fast system -- with tons of thump..!
You want a system that you will not upgrade in 4 years. That is currently difficult to manage. You PSU is low. Just the bare minimal. Down the line (4 years), you will probably put in more stuff...it will strain. Motherboard, if plan to go dual GPU -- you have a single PCIEx16 slot.
asingh is online now
Old 25-12-2009, 03:15 PM   #13 (permalink)
no im not planning to go dual gpu or make any upgrades to my system.. this will be final or about 4 yrs.. howz the reliability of the components mentioned? esp the mobo and psu?
Old 25-12-2009, 09:07 PM   #14 (permalink)
Super Moderator
asingh's Avatar
The reliability, is fine. If you will never change a part for the next four years....then HD5770. Sure, get it. What more can I say. Though let me tell you, 4+ years from now, your system will not be able to do much. Specially game.
Ideally one should always purchase stuff, to leave a wee-bit headway for upgrades. If you buy a locked down system, when you want to upgrade, you need to change the whole rig.
Old 26-12-2009, 08:31 AM   #15 (permalink)
paroh's Avatar
The cost of ATI HD 5770 including all taxes etc is around Rs.11990
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
Old 26-12-2009, 10:08 AM   #16 (permalink)
nope.. going for 5750...got the costs.. negitiationg the final and the cost of old system..5750 costs 9.1k inclusive vat
Old 27-12-2009, 03:02 AM   #17 (permalink)
Courage to Know
Anubis's Avatar
So u still wanna go for ATI 5750 @ 9.1k or ATI 4870 1gb @ 9.35k huh ?
Mark my words u'll eat ur own words when u start playing in DX9 mode leave alone DX11
Anubis is offline
Win XP SP3 Final (Expected this week) Yoda Technology News 9 20-03-2008 08:43 PM
Techniques to Hide One's Identity on Internet _mAkA_ Tutorials 12 17-08-2007 01:50 PM
Recovering from a corrupted regisry which is stopping windows xp to start piyushp_20 Tutorials 2 14-07-2007 01:40 PM
help.about blue screens.random messages.no hibernation hippi QnA (read only) 7 05-01-2006 07:52 PM
- by kool
