Old 20-12-2009, 11:02 AM   #1 (permalink)
Don't fear Rohan is here
Question Buying cheap BOOTABLE pendrive
Hi all,
I want to buy a cheap new pendrive which would be bootable and has a small(thin) form factor. I believe 8GB will suffice as i only wish to carry some important data(1GB) + 1 Operating System(probably Ubuntu portable version). The drive should be cheap.
Please give advice.
Additionaly, pls suggest where can i buy it in Delhi, as in where from Nehru Place
Thanks in advance.
rohan_kumar011 is offline
Old 20-12-2009, 03:27 PM   #2 (permalink)
CA50's Avatar
Default Re: Buying cheap BOOTABLE pendrive
Hey man all flash drive bootable, just select a gud one 4m da market. Better get drives 4m kingston, toshiba etc.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 20-12-2009, 04:52 PM   #3 (permalink)
Exclamation Re: Buying cheap BOOTABLE pendrive
Sorry to say but u've got it wrong there. I might not have much market/price knowledge but im clear that many drives available today in the markets are NOT bootable. I dont knw abt kingston but ive heard Toshiba and SanDisk Drive are bootable.
If any one used a specific one from any brand then pls tell me.
Old 20-12-2009, 06:29 PM   #4 (permalink)
CA50's Avatar
^^ why so all flash drive have got boot sector, only the mobo should support usb booting and that will make the flash drive a bootable one provided an os is loaded on it
| Nokia 2700c |
CA50 is offline
Old 20-12-2009, 06:49 PM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
All flash drives can be made bootable.. Just like all CD/DVDs can be made bootable
kalpik is online now
Old 20-12-2009, 08:30 PM   #6 (permalink)
live life king like...
hot zubs's Avatar
according to me Corsair z d best... its got 10 yrs of warranty v can get it replaced whenever it givesup... i'm using it from past 1yr it works pritty well...
n as said above all flash drives can be made bootable...
---------- Post added at 08:30 PM ---------- Previous post was at 08:27 PM ----------
According to me Corsair z d best... its got 10 yrs of warranty v can get it replaced whenever it givesup... i'm using it from past 1yr it works pritty well...
here in Bangalore v get it for 900 bucks for a 8GB drive...
Core i5 2400, Intel DH67BL-B3, 2GB Corsair DDR3, Geforce 8600GT, Seagate 1TB, LG 20x , BenQ E2220 HD, Creative M4500 , CM extreme 600W, CM 690, APC BackUPS -ES650VA
hot zubs is offline
Old 20-12-2009, 08:36 PM   #7 (permalink)
damnbadman666
damngoodman999's Avatar
Check on CORSAIR VOYAGER & SAN DISK CRUZER !!
Best brands
damngoodman999 is offline
Old 20-12-2009, 09:31 PM   #8 (permalink)
So hey maybe i was wrong about the boot thingy. Can anyone help me wit the price and size
Old 20-12-2009, 11:25 PM   #9 (permalink)
damnbadman666
Sandisk Cruzer is 4 GB 400 it seems
Corsair voyager @ the same level
Ultimate Boot CD and The bootmanager for bootable CDs Sourabh Tutorials 16 19-08-2007 11:28 AM
Buying Computer Components navino87 Hardware Q&A 17 03-12-2005 02:32 PM
A laptop buying Do's and Don't guide. rohitsz Laptops and Netbooks 17 06-07-2005 03:28 PM
Online buying of computer hardware in India cybershastri QnA (read only) 8 05-07-2005 11:48 AM
I can't understand the process of creating a bootable cd? K.R.L.Narasimha Software Q&A 2 23-03-2005 09:23 PM
- by kool
