Old 19-12-2009, 12:06 PM   #1 (permalink)
paralinux
Red face Bad Bad Sectors
Hi folks!!!
my external hdd has developed some bad sectors. Although I repaired using the tool in XP. I am already aware of the fact that it just set the OS to ignore the bad sectors and want to know whether the drive would behave normally even if I connect it to anther system (eg my linux distro) ??
thanks
anuvrat_parashar is offline
Old 19-12-2009, 12:40 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Bad Bad Sectors
Yes......It'll perfectly work in other systems also. BTW Bad Sectors cannot be repaired. Those r marked as ignored. Correct me if I'm wrong.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 19-12-2009, 01:59 PM   #3 (permalink)
paralinux
yes sir, you are correct and i knew that .. that why I said .. its set to ignore those sectors
thanks for your reply
Old 19-12-2009, 05:16 PM   #4 (permalink)
Simply a DIGITian
Its k......Any where u use the HDD the OS will ignore those sector. U can use that HDD anywhere.
Old 19-12-2009, 08:03 PM   #5 (permalink)
CA50's Avatar
try HDD regenerator to completely regenerate your HDD
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Bad Sectors He28 Hardware Q&A 2 29-12-2007 02:48 PM
VIA UniChrome Pro Display Driver ver 0.8 gary4gar Open Source 19 22-12-2007 02:09 PM
How to see bad sectors in XP ?? ~Phenom~ Hardware Q&A 16 16-02-2007 03:32 PM
Bad sectors on my Hard Disk anna_don QnA (read only) 3 13-01-2006 09:54 AM
- by kool
