Old 17-12-2009, 11:19 PM   #1 (permalink)
live life king like...
hot zubs's Avatar
Question Need help for buying a new system
hi all
i'm planning 2 buy a new system for my cousin for casuall gaming and home use
his budget is 25k-30k max n he needs Intel config only total no no for AMD config so plz suggest a intel config only
dis is d config which i hav thought
CPU - Intel core i5 750 2.66Ghz @ 9.3k
Mobo - Intel DP55WB @ 5.4k
RAM - Corsair 2GB DDR3 @ 1333Mhz @ 2.3k
Graphics card - Zotac GeForce 9600 GT Eco @ 4.3k
HDD - Wester Digital 500GB @ 2.6k
Monitor - AOC F19s @ 5.7k
DVDRW - LG 22x DVD @ 1k
Cabinet - Zebronics bijli @ 1.5k
Logitech Keyboard mouse combo @ 600
UPS -Tech-com 600VA @ 900
Total - 32k
*d mobo in d above config z not so good cant i get a better mobo within d budget ???
OR
CPU - Intel core 2 quad Q8400 2.66Ghz @ 8.4k
Mobo - MSI P7NGM Digital @ 6.3
RAM - Corsair 2GB DDR2 @ 800Mhz @ 1.8k
UPS - Numeric digital 800VA @ 2.1k
Total - 30k
jus went 2 SP road today n checked out d prices out der
wil add a PSU later
plz giv ur suggestions....
thanx a lot in advance....
Core i5 2400, Intel DH67BL-B3, 2GB Corsair DDR3, Geforce 8600GT, Seagate 1TB, LG 20x , BenQ E2220 HD, Creative M4500 , CM extreme 600W, CM 690, APC BackUPS -ES650VA
hot zubs is offline
Old 19-12-2009, 03:06 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Need help for buying a new system
Although at your budget AMD is the way to go, I'll try to suggest the best Intel mobo at your budget.
1stly don't go for the Core2Quad processors. They are old design and going to be phased out very soon. For your budget Core i7 is the way to go. So your 1st suggestion looks good to me. Only a few correction and addition
1. Graphics card: go for XFX 9600GSO 768MB DDR2 @ 4.2k. It is the special edition card and the best performer among all the 9600 cards because of its 96 SP count compared to the 64/48 of others. Best buy from also digit magazine
2. You have not added any Power supply Unit. The generic PSU present in the Zebronics Bijli won't be able to run the config u mentioned.
Go for the Gigabyte 80 Plus Active PFC 460W @ 2.2k
And if you want an AMD config, let us know. Beleive me, it will give u bang for every bucks. Most of the forum members also suggest u the same thing,
Cilus is offline
Old 20-12-2009, 01:34 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
AMD Phenom II X4 925: 7.5k
Gigabyte GA-MA785GMT-US2H: 5.5k
Graphics card - Sapphire HD4670 for 4.3k or 9600GT (non-eco): 4.7k
Monitor - Samsung 2033SW: 7k
desiibond is offline
Old 21-12-2009, 11:47 AM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
why?
Total - 32k
whats a core i5 doing in that rig? waiting to hatch eggs, or wait for shiny golden male roosters??
Get a phenom II config and a 9800GT instead, as suggested by Desi...or instead u can get a Athlon II X4 620 @ 5.3k too
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 21-12-2009, 09:40 PM   #5 (permalink)
hot zubs's Avatar
Originally Posted by comp@ddict View Post
why?
A total NO NO z not from me its from my brother who z gonna take dis system... I told him 2 get a AMD config but he does'nt understand it cant help... he needs only Intel configured system itseems...
hot zubs is offline
Old 22-12-2009, 08:25 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Aah well, if thats that, then go ahead..
About me:
Old 23-12-2009, 09:32 PM   #7 (permalink)
hot zubs's Avatar
Question Re: Need help for buying a new system
hey guys which z a better mobo with these 2 options Intel DP55WB and GA-P55M-UD2...
or please suggest me a good mobo fa intel core i5 750 within 6.5k...
n i hav a small question in my mind
in olden mobo's v use to have a pink port(which is called as Parallel port i guess) next to vga port which was used to connect Printers... dis pink port is not there in any of these mobo or any new mobo... den how r the printers connected to mobo these days???
thank u...
hot zubs is offline
Old 23-12-2009, 09:47 PM   #8 (permalink)
BE FREE
thank u...
they are obsolete, now they use USB ports.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 24-12-2009, 08:01 PM   #9 (permalink)
hot zubs's Avatar
Then my brother who is gonna buy dis new system is having a old printer in which der is a parallel port connector... den how do v connect dis in his new system were der is no parallel port in it...
do v get a converter of parallel port to USB port???
hot zubs is offline
Old 24-12-2009, 08:06 PM   #10 (permalink)
BE FREE
yes you can get an usb to parallel port adapter or if main board has a com port(which also obsolete) then com to parallel adapter
is the printer still functional.........
Old 24-12-2009, 09:08 PM   #11 (permalink)
hot zubs's Avatar
yeah man it still works...
hot zubs is offline
Auto system boot for scheduled download!!!!!!!!!!! phreak0ut Tutorials 13 27-08-2007 06:12 PM
Sony PlayStation 3 (60GB) kinshuk99 Gamerz 6 16-06-2007 12:02 PM
Very Strange Problem!!! shivaranjan.b QnA (read only) 1 15-06-2005 09:00 PM
- by kool
