i am unable to burn dvd/cd on my burner, using a sony dvd rw rw-q28a. the burn process starts ok, continues for some time then i get a "burn process failed" report. Using nero to burn dvd's find below the error report. is it time to get a new burner?
Error Report:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
(Nero Express)
Recorder: <SONY DVD RW DW-Q28A> Version: KYS3 - HA 1 TA 0 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <SONY DVD RW DW-Q28A >Version: KYS3 - HA 1 TA 0 - 7.8.5.0
=== Scsi-Device-Map ===
DiskPeripheral : ST3160827AS atapi Port 2 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DW-Q28A atapi Port 5 ID 0 DMA: On
=== CDRom-Device-Map ===
SONY DVD RW DW-Q28A G: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095600kB)
Free physical memory: 983MB (1007388kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
17.12.2009
ISO compilation
8:55:10 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
8:55:10 PM #2 Text 0 File Isodoc.cpp, Line 6608
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
8:55:10 PM #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
8:55:10 PM #4 Text 0 File Burncd.cpp, Line 3499
Turn on Disc-At-Once, using DVD media
8:55:11 PM #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2206399 (490:18.49, 4309MB)
8:55:11 PM #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
8:55:11 PM #7 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: SONY DVD RW DW-Q28A, Media type: DVD-R
Disc Manufacturer: MBI 01 - RG40
Disc Application Code: 64, Disc Physical Code: 193
8:55:11 PM #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
8:55:11 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2206400 (2206400) = #2206400/490:18.50
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2206400 blocks [G: SONY DVD RW DW-Q28A]
8:55:11 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [G: SONY DVD RW DW-Q28A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4518707200, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2206400 | 0 | 0x00
2206400 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
8:55:11 PM #11 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
8:55:11 PM #12 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
8:55:11 PM #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
8:55:11 PM #14 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
8:55:11 PM #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
8:55:11 PM #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 8x (11,080 KB/s)
8:55:11 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
8:55:11 PM #18 Text 0 File DVDR.cpp, Line 3192
Recording mode: Sequential Recording Mode
8:55:11 PM #19 Text 0 File DVDR.cpp, Line 3348
Start write address at LBA 0
DVD high compatibility mode: Yes
8:55:11 PM #20 Text 0 File Cdrdrv.cpp, Line 9859
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:55:11 PM #21 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
8:56:13 PM #22 Text 0 File Cdrdrv.cpp, Line 1338
20:56:13.296 - G: SONY DVD RW DW-Q28A : Queue again later
9:06:08 PM #23 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 1B E3 C0 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x0d77ddc0: Len x10000
0xC3 2C 0B 1A 2D F4 21 B4 26 BA 0E 44 E9 56 A0 23
0x37 D2 4D EB 8F A3 BB 41 3A 4A D3 D6 A9 41 74 E9
0x56 07 29 80 CF CB ED DA 0E 42 6F 22 D3 67 AB 33
9:06:08 PM #24 CDR -1135 File Writer.cpp, Line 303
Write error
9:06:08 PM #25 Text 0 File DVDR.cpp, Line 3750
EndDAO: Last written address was 1827775 (1BE3BFh)
9:06:08 PM #26 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 8x (11,080 KB/s)
9:06:09 PM #27 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
9:06:11 PM #28 Text 0 File Cdrdrv.cpp, Line 11214
DriveLocker: UnLockVolume completed
9:06:11 PM #29 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
