Old 16-12-2009, 09:10 AM   #1 (permalink)
Default Best AMD Processor
hi,
i am planning to upgrade my pc.
right now i am using AMD Athlon with ASUS M2N MX SE Plus motherboard
i am planning to upgrade my pc to AMD Phenom
please advise me on the best available processor under Phenom category
and the best mother board suited to it (for home pc).
i want good quality sound and graphics with minimum 4 sata interface. upto 4GB ram.
or please tell me a site where i can compare prices and performance of
amd processors and motherboards compatible with it
thanking you in advance
murphyker is offline
Old 16-12-2009, 09:53 AM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: Best AMD Processor
If u r going to upgrade only processor then choose Phenom 2 550 or Athlon 2 X4 620 !!
damngoodman999 is offline
Old 16-12-2009, 09:58 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
what's your budget dude?
desiibond is offline
Old 18-12-2009, 07:27 AM   #4 (permalink)
thnaks damngoodman!
will the new processor phenom will fit into my existing mother board.
my processor is amd 64 X2 codenamed "brisnbane"
Old 18-12-2009, 10:55 AM   #5 (permalink)
damnbadman666
Originally Posted by murphyker View Post
thnaks damngoodman!
Yes it will fit , u need to update the motherboard bios thats all .
Old 21-12-2009, 11:43 AM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get:
Phenom II X3 425 @ 4.2k
MSi 785GM E51 @ 4.6k
2GB DDr3 Transcend @ 2.5k
Total = 11.3k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 21-12-2009, 01:16 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I wouldn't recommend putting Phenom II on ASUS M2N MX SE Plus. It's really old board with 6100 chipset on it. If you want to use this board, better get Athlon II
It's time for AMD to give it up Indyan Technology News 21 19-12-2007 05:50 PM
Amd cuts single core processor prices cyrux Hardware Q&A 7 02-07-2006 03:53 PM
overclocking amd processor ramana321388 Overclocking 2 20-06-2006 07:44 PM
AMD Processor FAN Problem satya_gen CPU / Motherboards 2 15-07-2005 08:07 PM
No!!!! Branded PC AMD Processor available in India Godhatesusalllll CPU / Motherboards 7 04-04-2005 10:44 AM
- by kool
