14-12-2009, 09:15 PM
BLUE IS THE COLOUR
Need a gaming rig at lowest possible price
I dont need all things its just upgradation
My idea is
Q8400.........7.7k
Asus p5QPL .......3k
Corsair ddr2 2gb.......2.5k
Cooler master 330 with smps.......3k
Can i get similar configuration below 15k with out reducing quality?
U can have a look at my current config
vvvvvvvvvvvv
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
14-12-2009, 09:30 PM
Simply a DIGITian
Re: Need a gaming rig at lowest possible price
Is this a gaming rig?? I dont think so........Where is thr graphics card??
@15k I wud suggest u to go for AMD........It'll give u better rig than Intel at ur budget
Well.......wait for Krow.......he can give u ideal config for ur price.....!!
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
14-12-2009, 09:51 PM
laborare est orare
Your idea is little confusing. For example no Gfx card. And if you wanna go cheap, then AMD is the way to go, not Intel. I am suggesting you an AMD based solution
Athlon II X4 620 2.6GHz @ 5.1k
MSI 785GM-E51 @ 4.6k
Kingston 2GB DDR3 1333MHz RAM @ 2.6k
Zebronics Bizli Cabinet @ 1.4k (without SMPS)
Keyboard and Mouse of your choice @ 0.8k
Seagate Barracuda 7200.12 500GB @ 2.4k
LG 22x DVD @ 1.1k
BenQ G2020HD 20" LCD Monitor @ 6.5k
TAGAN TG500-U37 500W PSU @ 3.5k or Gigabyte 80 Plus Active PFC 460W @ 2.2k
PowerColor HD4850 1GB GDDR3 @ 7.2k
This is one of the cheapest config for a very good config. But u need to be very specific. it is not clear wheather you wanna buy all the components or just Processor, Mobo and ram. Then only we can suggest proper configuration for your budget.
14-12-2009, 10:23 PM
Courage to Know
Processor: Athlon II X4 620 - 5.3k
Mobo - MSI 785GM - E51 - 4.6k (onboard ATI HD 4200 is a very good IGP. Plays HD with eaze and directX 10.1 complaint)
RAM: Transcend 2GB DDR3 1333MHz - 2.6k
Cabinet: Zebronics Bijli ATX with 400w SMPS - 1.7k
Total - 13.9k
There you go . More performance than your rig and @ 13.9k
Cut down on cabby and Psu. U wont need so much when u want rig
The quality is not reduced. Only cabby has ben cut down if you wanna make below 15k
Athlon II x4 620 performs better than Intel q 8400
Moreover u won't have to buy GFX
The onboard IGP ATI HD 4200 will be enough for u
14-12-2009, 10:45 PM
BLUE IS THE COLOUR
Thanx for ur replies
But i dont need all things. Have a look at my signature i need only
Proccy
Mobo
Ram
Cabby
Now i hav 9500 GT so will by GFX card later
New config from ur suggestions would b
doubts
Can i go for cheaper mobo if i dont want internal graphics but with ddr3 support?
Does this cabby has enough cooling?
14-12-2009, 10:53 PM
Courage to Know
Proccy
Mobo
Ram
Cabby
doubts
Really bro , it can't get any cheaper than this
And i mean it , it cant get cheaper anymore
This is the cheapest . No other DDR3 mobo below 4.6k and without IGP
I saw from ur post that u needed CPU+Mobo+RAM + Cabby
That's y i posted those 4 only
16-01-2010, 11:29 PM
BLUE IS THE COLOUR
1 doubt can i use my nvidia 9500 GT in that config? Someone told me that its not supported in AMD based config.Is there any conflict between AMD and nvidia?
16-01-2010, 11:34 PM
Simply a DIGITian
^^I dont think so. Even I've never heard such thing. But dunno whether the rig will be overkill for this gfx card. Anubis can tell you better.
28-01-2010, 04:50 PM
Legendary Darknight
U can use ur 9500GT without any problems... It will work just fine...
29-01-2010, 01:42 PM
BLUE IS THE COLOUR
This board is an ATI chipset board.Can i use may Nvidia 9500 GT in it..? My friend told me that Nvidia cards wont work in ATI chipset boards.For that i have to go for Nforce chipset board its slightly expensive and fewer.
I dont need SLI or crossfire but i need to use my Nvidia card in AMD based rig
29-01-2010, 02:54 PM
laborare est orare
Then your friends know nothing. Its little harsh, but true. There is nothing like Nvidia cards can't be used in AMD/ATI chipset based board or vise versa.
Only for crossfire or SLI the Mobo chipset comes in piture. Like u can't SLI in an AMD board or Crossfire in a Nvidia chipset board. For a single GPU, there won't be any problem. Go without any hesitation.
29-01-2010, 04:43 PM
BLUE IS THE COLOUR
Thanx for the info.
I need to show him your words.
29-01-2010, 05:27 PM
yea ... you can use Nvidia cards on ATI chipset without any problems !!
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
29-01-2010, 06:00 PM
very TRUE.
AMD Chipset, 790GX, 790X, 790FX & even some 785G supports CrossFireX only.
Nvidia Chipsets support only SLI.
Intel X58 support SLI & Crossfire both.
H55, H57 support CrossfireX only if theres 2 PciE X 16 slots.
& what abt P55 frnds? Crossfire yes. wbt SLI?
29-01-2010, 11:13 PM
EXIT: DATA Junkyard
Athlon II X4 620 2.6GHz @ 4.9k
MSI 785GM E51 @ 5.4k
2GB C9 DDR3 1333MHz Transcend @ 2.5k
CM Elite 310 @ 1.6k
Seasonic 380W Bronze @ 1.6k
Total = 16k
30-01-2010, 11:27 AM
BLUE IS THE COLOUR
But MSI 785GM E51 is @ 4.8
30-01-2010, 01:32 PM
EXIT: DATA Junkyard
CHANGE:::
ECS A785GM-M @ 4.8k
CM Elite 310 @ 1.6k
11-02-2010, 01:17 PM
BLUE IS THE COLOUR
MSI doesnt have much dealers here(cochin, kerala) because of some warranty issue.Also ECS is rare.
Can u suggest some good mobos from various brands suited for amd
athlon II X4 ?
I have a 9500 GT to use in that mobo
ECS MCP61M-M3 looks gud since its cheap and AM3+DDR3. But dunno whether its available here.
Is it worth to go for DDR3 now? since mobos for DDR3 are highly priced.
I need a suggestion on wireless KB & M
Is it worth to go for it? Do we need to change batteries often?
I found some in microsoft and logitec. My budget for that is 2k
Proccy
mobo
ram
cabby+smps
Wireless KB & M
total 15k
Thats why i hesitate to go for a highly priced mobo.I have 9500 GT and creative sound blaster audio card.
11-02-2010, 07:35 PM
#19 (permalink)
BLUE IS THE COLOUR
PLzzz reply its urgent.Going to buy tomorrow or saturday
