Old 10-12-2009, 10:21 AM   #1 (permalink)
eagle_y2j's Avatar
Default Buying Advice 4 LCD Monitor
I am planning to buy new LCD monitor ,my budget is 10-13k .
Screen Size 22" or more needed .
Inbuild Speaker would act as a plus point .
Guys suggest me some gud LCD monitor at this budget .
At present I am considering Acer H233H .
TIA
Registered LINUX USER #438929
eagle_y2j is offline
Old 10-12-2009, 12:19 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Buying Advice 4 LCD Monitor
well, inbuilt speakers are NOT of a very good quality.. so if u hv separate speakers, tat wud be way better..
tat Acer LCD is a good choice, but it has a glossy screen instead of the regular matte screen, if u are okay with it, then its good..
Else, Samsung 2233SW (fullHD, no speakers, no hdmi cable) 1920x1080 is also a good option priced at Rs. 10.5K
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 17-12-2009, 02:20 PM   #3 (permalink)
eagle_y2j's Avatar
Frnds what is difference between TN and non TN monitor ?
PS:- Any body from Jaipur can please availability of Acer H233H in Jaipur ? In my State they sale only 18.5' displays
Planning to visit Jaipur too buy this monitor .
Old 18-12-2009, 12:36 PM   #4 (permalink)
Cool Buddy's Avatar
Make sure the monitor you buy is full HD (i.e. supports a resolution of 1920x1080). I think you can go for 24" screen at this budget. Samsung's monitors are good, but check the stand, they are not very stable
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
lcd monitor screen protection rk Hardware Q&A 1 24-09-2009 09:06 AM
difference between LCD monitor and LCD TV? naru TVs / Monitors 6 13-09-2009 08:32 PM
Opinion about 19" LCD Monitor hailgautam Hardware Q&A 13 05-07-2007 08:35 PM
lcd monitor with svideo/composite inputs for tatasky help?? vivekbabbudelhi Hardware Q&A 6 10-03-2007 01:10 PM
- by bhaskar
