Originally Posted by akshayt
Just FYI, MSI is one of the best enthusiast mobo makers out there and MSI P55 GD65 and GD80 are one of the best P55 motherboards available. My motherboard performs within a margin of 1-2% of the Asus P7P55D Evo and is sometimes faster, almost equally good in overclocking and almost 5k cheaper. Besides, it has won HardOCP's award for VFM enthusiast board.
Just fyi, there are times that manufacturers and reviewers collaborate, hence reviewers write advertisements/give awards in the form of advertisement. Its usually asus' non rog board with has lesser bugs but keeping the price point in mind, you could have easily afforded a gigabyte or a dfi boards, rather you chose something made on awards
. I am not saying msi is all that bad, but seriously for that money, gigabyte and dfi boards can be bought.Msi are supposed to be cheaper than these brands but our distris are notorious and have a colourful personality when it comes to labelling a price tag on certain products.
If you are going to install true120e, remember 2 things.
# In coastal area, true120e and true120e black do corrode eventually. But when black corrodes, the paint comes out.
# Use the bolt on which secures over all 4 corners on top of the heatsink and use the metal plate provided rather than scissor type bolt ons as they dont completely secure the heatsink on the motherboard properly. Assuming the msi board is one with one of those flexing types and the motherboard plate of your case and the brass standoffs are good enough so that they wont buckle/ bent under the pressure of the hsf and the card, make sure there enough depth- no I wasn't talking about the hsf to fit in. In certain scenarios, if a cable management is not done properly and there's no proper airflow, what's the point in having a good heatsink when there's no adequate airflow in the first place. Make sure the case has atleast 120mm 50 cfm fans for the front and for the rear.
I also assume you have bought the true120e rev C. This is the one with ifx type heatbase, good enough am2+/3 mounts and an extra fin on the top.
