Old 09-12-2009, 12:20 PM   #1 (permalink)
The Master Chief
Ronnie11's Avatar
Default DVD Player for 32" LCDTV
Hey guys i need help with a dvd player for a lcd tv which allows usbs to play movie etc...preferably a samsung brand..no idea how much budget needs to be allocated,so if anyone could pls help me out with it..for now its about 5-6k...
Ps:- i didn't know as to which section i should oput this question,if this section is wrong,plsfeel free to move it...
Intel Core I5 2500K,Gigabyte GA P67A UD3 B3,Corsair Vengeance 4gb DDR3,CM430 Cabinet,Corsair VX550W,Razer Cyclosa Bundle,Seagate 250GB,500GB,1TB,MSI 5770 hawk
Ronnie11 is online now
Old 09-12-2009, 12:51 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: DVD Player for 32" LCDTV
Good query. See, mostly you will get DVD players which have USB playback, but most are limited to playing Divx/Xvid codecs only. This means that mostly they will mostly play movies in .avi and .divx format from USB. Your best bet is to take a couple of USB drives to the store with mp4, mkv, mov formats as well as avi format videos. Check out all DVD players and see if they play them. If yes, then buy, else, you will mostly end up being limited to AVI/DIVX formats.
This is what I found out. I was looking for a Home Theater setup and not just a DVD player. Your budget is great, it will buy you what you need easily. Be wary of players proced above 5k as mostly they are not worth the premium.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 09-12-2009, 07:24 PM   #3 (permalink)
The Master Chief
Ronnie11's Avatar
Ahh Thanks a lot Krow for the reply,helped a lot,i actually did the exact same thing,i had gone to a reliance store with a usb to check if it supports movies other than the DIVX format,unfortunately most of the models i tried din't support it,but thanks a lot for the suggestion & about the budget,will keep an eye for models above 5k...
Old 09-12-2009, 08:01 PM   #4 (permalink)
Crowman
Krow's Avatar
Look for a good bundle. Some players give out an HDMI cable free with them, so look out for HDMI connectivity and the free cable. And look for a player which supports FULL HD upscaling as you have a 32" TV. That's all I can help you with. All the best for your purchase.
Krow is offline
Old 10-12-2009, 11:49 AM   #5 (permalink)
Instead of going for a DVD player you can go for WD TV which plays content of external hard-disc/USB drives. It is able to play all kind of formats and also the firmware is upgradable to incorporate the new codecs to come. Check the link below for the formats supported.
http://www.wdc.com/en/products/Products.asp?DriveID=734
Its 99$ in US. The price in India should be around 7k.
Now if you further need a DVD player for CD/DVDs to play you can go for any low-cost DVD player which can play those (no need for DivX support or USB port). WD TV + Low cost DVD player (preferably Philips) will be the best and futureproof option.
winzip is offline
Old 12-12-2009, 10:44 PM   #6 (permalink)
anubisX's Avatar
You can try a Samsung HD Player which will cost you 5K but you won't be able to play HD formats. They don't even have DTS encoding. They will upscale well. Anyways, I would go for WDTV or the Xtreamer (check xtreamer.net). If you buy Xtreamer, you can use WiFi to just stream from your PC DVD-RW.
Asus P5Q-E | Intel E8400 with OCZ V2 | Corsair 6400 C5 4GB | Seagate 1TB | WD 1TB | Radeon HD3650 512MB | Tagan 600W | Thermaltake VI6001 StrikeMX | Samsung 32B530 | Logitech Z-5500 | Sony MDR-XD200
anubisX is offline
Old 13-12-2009, 04:19 AM   #7 (permalink)
+1
Exactly, the same thing came to my mind. But instead of 7k, it is actually available just for a little over 5k.
ico is offline
Old 13-12-2009, 10:19 AM   #8 (permalink)
The Master Chief
Ronnie11's Avatar
hmm....had no clue about WD tv,thanks for the suggestion...will check it out...
!!! Guide To Copy DVD Movies !!! go4saket Tutorials 38 01-06-2008 03:50 PM
Now problem in the DVD player moshel Hardware Q&A 1 13-11-2007 06:56 AM
WinX DVD Author the best tool to Personalized DVD from Your Own Video in Clicks bigit Random News 2 21-06-2007 01:15 PM
SEARCH FOR A DECENT 5.1 DVD PLAYER PCWORM Software Q&A 5 09-02-2006 03:35 PM
- by bhaskar
