Old 08-12-2009, 08:04 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Angry Getting low FPS in GTX 275 oc
CPU - AMD Phenom2 X4 810 - 2.66Ghz
Motherboard - Zotac 8200
RAM - 3GB OCZ
GPU- Zotac GTX 275 Amp edition!!
Hard disk- Segatte 250 GB & WD 500 GB in RAID 0
PSU - TAG 750W
Monitor - AAOC 2236Vm
when i had brought my new config. all the games were workin properly at ressolution 1920*1080 with high settings
FPS meas using FRAPS
GRID -60 FPS
Burnout - 60 FPS
Cyrsis -40 FPS
HD videos were running smoothly
but now suddenly all games have reduced FPS being shown !!!!!!!
GRID- 25-30FPS
Burnout - 35-40FPS
Cyrisis -25-30 FPS
temp of each component (using speed fan)
HDD both around 38-40 c
GPU around 50 (idle) & 80(load)
CPU around 36(idle) & 40(load)
Please Help !!!!!
i even formatted the c:drive & scanned for viruses using Kaspersky 2010
i even cleaned dust from inside the cabinet but to no vain
all drivers are updated with nvidia driver (191.07) & directX 9(Aug09)
now HD videos are also lagging with sound leading first & then the video comes!!!!!
sandeep410 is offline
Old 08-12-2009, 08:17 PM   #2 (permalink)
I am the night! I am....
vickybat's Avatar
Smile Re: Getting low FPS in GTX 275 oc
hi sandeep
In your case i think some unwanted background programs maybe the culprit.Either they may be viruses or vbscripts.Try to full format your hdd's and then try.
Back up your data and try a complete format and delete all partitions.Reinstall the os and again check the fps benchmark and post the results.
Hope its gonna solve your problem.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 08-12-2009, 08:26 PM   #3 (permalink)
Crowman
Krow's Avatar
Default Re: Getting low FPS in GTX 275 oc
TAG 750W? Which PSU is that? Is it any good?
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 08-12-2009, 08:52 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Could you run GPU-Z see and see the link width you are getting for the card. The bus interface value shoud be @ 16.
If it is not @ 16, pull out the GPU, blow a few times hard into the PCI.E slot, and reseat the card.
---------- Post added at 08:52 PM ---------- Previous post was at 08:50 PM ----------
It is a TAGAN...!
asingh is offline
Old 08-12-2009, 08:55 PM   #5 (permalink)
Never give up!!
jerrin_ss5's Avatar
actually that sandeep person is me !!!!!
i used my friends account to post ,cause i was not a member, now i am !!!!!!!
---------- Post added at 08:55 PM ---------- Previous post was at 08:53 PM ----------
ya!!!! i am getting @16 bus link
jerrin_ss5 is offline
Old 08-12-2009, 09:03 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Okay try Drive Sweeper pro in save mode. See if any left over driver crumbs are there.
asingh is offline
Old 08-12-2009, 09:05 PM   #7 (permalink)
Never give up!!
jerrin_ss5's Avatar
which is that software ???????
& what does it do ???
Old 08-12-2009, 09:07 PM   #8 (permalink)
Super Moderator
asingh's Avatar
It checks all the drivers and support files you have on your system pertaining to GPU/and sound. And if there is anything unwanted you can remove it (with a backup option). If there is any conflict you will see it.
Please create a roll-back restore point before you run it.
asingh is offline
Old 08-12-2009, 09:09 PM   #9 (permalink)
Never give up!!
jerrin_ss5's Avatar
where do i get the software from ???????
i searched in google but was finding data sweeper s/w etc !????
Old 08-12-2009, 09:18 PM   #10 (permalink)
Super Moderator
asingh's Avatar
http://driver-sweeper.en.softonic.com/
asingh is offline
Old 08-12-2009, 09:23 PM   #11 (permalink)
Never give up!!
jerrin_ss5's Avatar
ya i will try that in safe mode & reply to u !!!!!!!
Old 08-12-2009, 09:37 PM   #12 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
What more does Driver Sweeper do than CCleaner?
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
Old 08-12-2009, 10:00 PM   #13 (permalink)
Never give up!!
jerrin_ss5's Avatar
when i pressed analyse button for checking Nvidia display drivers it should many files i ran the clean option & when i rebooted it the display came like there was no display driver installed (800 x 600 res) so i restored the files
please help !!!!!!!!!!
Old 08-12-2009, 10:08 PM   #14 (permalink)
Super Moderator
asingh's Avatar
What is ccleaner.
Did it show any files, from previous installations...?? You were not supposed to delete your current driver files...
asingh is offline
Old 08-12-2009, 10:22 PM   #15 (permalink)
Never give up!!
jerrin_ss5's Avatar
is there any way to post imaged ???
it shoud many files !!!!!!
but how to know whether it is from prev installations !!!!!!
is there any s/w to test whether graphics card is working properly ????
---------- Post added at 10:22 PM ---------- Previous post was at 10:17 PM ----------
ccleaner is used to clean temp files & registry leftovers
Old 08-12-2009, 10:33 PM   #16 (permalink)
Super Moderator
asingh's Avatar
oh..Crap Cleaner. Not that is different.
Make a screen shot, save it as .JPG. Upload to imageshack, and post here.
asingh is offline
Old 09-12-2009, 09:44 AM   #17 (permalink)
Never give up!!
jerrin_ss5's Avatar
http://img268.imageshack.us/img268/2...layedfiles.jpg
these were some of the files displayed
Old 09-12-2009, 10:28 AM   #18 (permalink)
Super Moderator
asingh's Avatar
Seems fine to me. Last I can suggest roll back drivers to the previous version.
asingh is offline
Old 09-12-2009, 10:32 AM   #19 (permalink)
Never give up!!
jerrin_ss5's Avatar
i did try the old drivers but still no use !!!!!!!
i suppose some virus attack might have taken place b,coz even HD videos are not runnin properly !!!!
Old 09-12-2009, 10:58 AM   #20 (permalink)
Super Moderator
asingh's Avatar
Mmm....could be
Try Spybot
asingh is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/123120-getting-low-fps-gtx-275-oc.html
background, displayedfiles, imageshack - 32478 This thread Refback 07-08-2010 06:17 AM
Good news for Intel G965 Users who use integrated graphics yesh1683 Gamerz 791 13-06-2010 09:16 AM
Creating an extremely low cost Value PC gxsaurav Tutorials 37 18-05-2008 08:07 PM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Laptop Hang When Dialing CDMA Modem sukanta Software Q&A 2 23-01-2008 02:55 PM
Low , Mid , High End AMD 64 PC Configs for All quad master CPU / Motherboards 29 10-06-2005 10:29 PM
- by bhaskar
