Old 08-12-2009, 07:33 AM   #1 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
Cool PC is not starting !!!
My pc was working properly last night.I started my pc in morning..it didnt start...I got error.. Bootmanager coruppt..... after other restarted new errror " system halted "..
ab to display bhi nhi aa rha h ...and not able to get into BIOS..
help me guys....
Asus P5K Premium | Q6600 | 4GB(2x2GB) | 550VX | Seagate 500GB + WD Black 1TB HDD |
Sapphire HD5850 1GB |Viewsonic 1940w | CM Hyper 212 Plus | CM Elite 330 |
Acer 5738G | N73ME | Samsung Galaxy ACE
sxyadii is offline
Old 08-12-2009, 08:56 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: PC is not starting !!!
>_< Dear God man! How on Earth do you expect people to understand when you are using morse codes between sentences. You have a full-fledged board with each key for each alphabet right. How hard is it to be relevantly detailed and not use so many dots? And why are you using 5850 with that psu?
No biggie
Correction: No biggie, assuming its not a HW issue. If so, it will point directly/indirectly to the psu.
First check in the bios if the hard drive is getting on the bios. After that, reinstall the BCD. Boot the system using the vista disc and go to the vista setup after POST. Use the repair option and when a system recovery option comes up, open command prompt type "Bootrec /RebuildBcd" without the quotes and press enter.
Hardware BBQ
The Sorcerer is online now
Old 08-12-2009, 09:50 AM   #3 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
Not getting any output to Monitor, I tried with two graphics card but nothing work.,system is running
sxyadii is offline
Old 08-12-2009, 10:04 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Try the repair option via the OS disc.
asingh is offline
Old 08-12-2009, 10:09 AM   #5 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
^ Not able to get into BIOS,this is problem
sxyadii is offline
Old 08-12-2009, 10:29 AM   #6 (permalink)
Super Moderator
asingh's Avatar
Pull out the CMOS battery for a while, make sure the power is off. Reset the bios, from the mother board..?
asingh is offline
Old 08-12-2009, 10:39 AM   #7 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
I did it already but nothing works,and it is hard to me remove HD5850 again-n-again to reset BIOS .
sxyadii is offline
Old 08-12-2009, 10:44 AM   #8 (permalink)
Super Moderator
asingh's Avatar
One RAM stick....only...?
asingh is offline
Old 08-12-2009, 10:46 AM   #9 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: PC is not starting !!!
U've three RAMs, try one at a time.
The first error may be cause of missing/corrupt system file.
But second and third error can be due to
1>RAM
2>PSU
3>Dead MOBO (No display, happened to me)
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 08-12-2009, 10:49 AM   #10 (permalink)
Change the sata cables, ports, sata/molex power connector. If it doesn't work despite doing all this, the hard drive is dead. See if you can get through post after physically disconnecting the hard drive from the system. If the system boots through POST without the HD connected, The HD is surely fried. If it doesn't, there could be something else that's a problem. To completely rule out whether the HD is damaged or not, connect the HD on another system and see if it gets detected on another system. If it does, boot to windows, google and download HD tune and run an error scan. If there's no corruption on the HD, the HD is safe.
To isolate and troubleshoot for the rams, google and download memtest 86+. You will get the instructions on how to run memtest with the ISO or google out for instructions. Run the test for 6 hours to completely rule out the ram's instability. If it fails, RMA it.
If either doesn't work, get an obsolete, low powered GPU, connect it and see if you can get the display. If it does, problem is the GPU. If it doesn't, it can be the psu or the DIMM slot of the mobo.
Do note that its best if you do all 3 even if you have found 1 of the hardware components is the source of the problem.
If there is warranty time left, send it for replacement. To be on a safer side for the long term, change the psu.
Hardware BBQ
Old 08-12-2009, 10:53 AM   #11 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
When I put 1 stick of ram and clear CMOS.it started, but after few second,it shutdown...
sxyadii is offline
Old 08-12-2009, 10:55 AM   #12 (permalink)
Super Moderator
asingh's Avatar
Try alternate sticks of ram. Different slots.
asingh is offline
Old 08-12-2009, 11:23 AM   #13 (permalink)
Courage to Know
Anubis's Avatar
May be ur problem lies here bro
Asus P5k Premium WIFI-AP Mobo,Intel C2Q Q6600 2.4GHz,
3x1GB DDR2 667MHz, Seagate Baracuda 7200.12 500GB HDD, ]Cooler Master Xtreme 500W PSU
Sapphire HD5850 1GB GDDR5, CM Hyper 212 Plus CPU Cooler..
Its the Cooler Master Xtreme 500W PSU
How on Earth is it suitable for running ATI 5850
Anubis is offline
Old 08-12-2009, 12:43 PM   #14 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
Dont say yaar
---------- Post added at 12:43 PM ---------- Previous post was at 11:43 AM ----------
Somehow the computer was running,running well with 2gb,when I want to start with 3gb ,and doesnt start window and it stopped here
sxyadii is offline
Old 08-12-2009, 01:13 PM   #15 (permalink)
Super Moderator
asingh's Avatar
It should not be in Asymmetric mode.
This mode is equivalent to single channel bandwidth operation for real world applications. This mode is used when only a single DIMM is installed or the memory capacities are unequal. Technology and device width can vary from one channel to the other. If different speed DIMMs are used between channels, the slowest memory timing will be used.
Put your RAMs in alternate DIMMS. 1st and 3rd. Stop using the 3rd DIMM.
asingh is offline
Old 08-12-2009, 01:16 PM   #16 (permalink)
Fullbring
Zangetsu's Avatar
its better if u refer your machine to service center....if its under warranty...
the culprit cud b nething RAM,Mobo,HDD etc
Zangetsu is offline
Old 08-12-2009, 01:17 PM   #17 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
I wish this error should've happened to me . I could've bought a new PC.
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
Old 08-12-2009, 01:58 PM   #18 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
I did just like you said,I putted 2x1GB stick on 1st and 3rd slot ! PC is running and become slow too ! but I m not able to run window with 3x1GB stick ! how can I run??
sxyadii is offline
Old 08-12-2009, 02:07 PM   #19 (permalink)
NVIDIAGeek's Avatar
^You know what I suggest, sell those RAM sticks & PSU if ye can, and buy new DDR3 sticks & Corsair 620W or CM 600W PSU. I should run like you've imagined.
CRYSIS 3 FOREVAH!
Old 08-12-2009, 02:16 PM   #20 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
but my mobo supports only DDR2 ram upto 1066Mhz.
sxyadii is offline
Old 08-12-2009, 02:20 PM   #21 (permalink)
Super Moderator
asingh's Avatar
= chance pe dance
asingh is offline
Old 08-12-2009, 02:34 PM   #22 (permalink)
NVIDIAGeek's Avatar
^O' course .
@adii - How many years have you been usin' those RAM sticks?
CRYSIS 3 FOREVAH!
Old 08-12-2009, 02:37 PM   #23 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
^O' course .
22 MONTHS ! In FEB, 2 yrs will complete
sxyadii is offline
Old 08-12-2009, 02:40 PM   #24 (permalink)
NVIDIAGeek's Avatar
^Darnit! Time to change. Are ye a "Darn! I can't buy HD5970" guy, know what I mean?
CRYSIS 3 FOREVAH!
Old 08-12-2009, 03:02 PM   #25 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
PC is running fine with 2 DIMM,Thnx for your help
Will purchase 2x2GB DDR2 1066MHz soon.!
sxyadii is offline
Old 08-12-2009, 03:20 PM   #26 (permalink)
Super Moderator
asingh's Avatar
Disable the AERO on win7.
asingh is offline
Old 08-12-2009, 03:33 PM   #27 (permalink)
NVIDIAGeek's Avatar
^Which's better DDR3 or DDR2? For gamin'.
CRYSIS 3 FOREVAH!
Old 08-12-2009, 03:35 PM   #28 (permalink)
Fullbring
Zangetsu's Avatar
DDR3
Zangetsu is offline
Old 08-12-2009, 03:45 PM   #29 (permalink)
NVIDIAGeek's Avatar
Phuc!
CRYSIS 3 FOREVAH!
Requirements for Setting Up A Home Network caje143 Software Q&A 2 05-04-2007 04:52 AM
top 20 tips to speed up your pc readermaniax Tutorials 3 12-12-2005 09:54 PM
monitor not starting - no display - nothing???? sincereheart QnA (read only) 7 26-05-2005 05:39 PM
PC Upgrade Help iinfi QnA (read only) 17 19-05-2005 07:26 AM
HELP ME!!! MY PC IS FREEZING sreevirus Software Q&A 5 10-10-2004 12:47 AM
- by bhaskar
