Old 02-12-2009, 11:31 AM   #1 (permalink)
I am the night! I am....
vickybat's Avatar
Default HSF for core i5
hi guys
recently bought the i5 and was impressed with its performance despite being a non overclocker.But the stock intel hsf emits a lot of humming noise which is audible & sometimes irritating.
Is this normal
Do i have to go for a cpu cooler to avoid any problems in future
I dont have any plans for oc cause i use intel dp55wb board but if the hsf is faulty then please suggest a good one.
Watin for replies
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 02-12-2009, 01:38 PM   #2 (permalink)
vickybat's Avatar
Default Re: HSF for core i5
hey guys please reply.........
vickybat is offline
Old 02-12-2009, 01:48 PM   #3 (permalink)
Courage to Know
Anubis's Avatar
Change your HSF . Not good at all
If you have no plans to overclock then Cooler Master Hyper TX3 - 1.2k is fine.
If you want to overclock then CM Hyper 212 + ~ 2k is great VFM . It supports LGA 1156 and offers great temperatures
Anubis is offline
Old 02-12-2009, 02:51 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Originally Posted by vickybat View Post
hi guys
Is this normal
Watin for replies
You could try to reseat it. What temperatures you getting --- RealTEMP software..?
asingh is offline
Old 02-12-2009, 03:15 PM   #5 (permalink)
sriharsha_madineni's Avatar
hi guys
Is this normal
Watin for replies
Vicky regarding the humming sound,change the fan speed and response modes in bios,try it first if you are not satisfied then look for a new HSF,also do check whether
it is seated properly.I had a problem with my stock intel hsf too which was not seated properly.
As asigh said do run a real temp test it gives you the complete picture,Hope this helps
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now
Old 02-12-2009, 03:26 PM   #6 (permalink)
Super Moderator
asingh's Avatar
^^ Yea, and post it with the full run (Prime95). Screenshot.
asingh is offline
Old 02-12-2009, 05:26 PM   #7 (permalink)
vickybat's Avatar
ok guys i will check the mounting and the bios settings.
Do i have to run the prime95 benchmark and then a temp. test?
vickybat is offline
Old 02-12-2009, 05:27 PM   #8 (permalink)
Super Moderator
asingh's Avatar
You run RealTEMP, and via that you run Prime95 (2x worker threads) to stress the system.
So basically RealTEMP records, and Prime95 stresses.
asingh is offline
Old 02-12-2009, 05:38 PM   #9 (permalink)
vickybat's Avatar
ok buddy i will do it and post the screenshot tonight as soon as i get home.
vickybat is offline
Old 02-12-2009, 05:45 PM   #10 (permalink)
The Sorcerer's Avatar
Hey does you motherboard's LGA 1156 socket has "foxconn" imprinted by it?
But honestly you should reseat it, update bios and use the latest temperature monitoring software, most probably TJ max is offset.
Hardware BBQ
The Sorcerer is online now
Old 02-12-2009, 08:29 PM   #11 (permalink)
Crowman
Krow's Avatar
Try and get good thermal paste before a good cooler. For stock speeds, no need for an aftermarket cooler.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 02-12-2009, 10:32 PM   #12 (permalink)
maverick786us's Avatar
TRUE is the best Heat Sink that will tame that monster well, and its price is reasonable. For thermal paste get Arctic Silver 5
(Gaming Rig) Intel E8400 @ 3.6Ghz, ASUS P5Q Pro, 4GB G.Skill DDR2 800, WD 6400AAKS HDD, MSI Cyclone GTX 460, Corsair 650TX, CM 690, Dell SP2208WFP (22 inch), Windows 7 Ultimatum 64
maverick786us is online now
Old 02-12-2009, 11:09 PM   #13 (permalink)
vickybat's Avatar
@ asigh
posting the screenshots have a look
vickybat is offline
Old 03-12-2009, 09:47 AM   #14 (permalink)
Super Moderator
asingh's Avatar
Not able to view it. After I download the image, only see a blank.
Could you please embed it directly as an image here on the forum. Much easier...!
asingh is offline
Old 03-12-2009, 10:19 AM   #15 (permalink)
vickybat's Avatar
Not able to embed it
how to do it
anyway the results are:
max temp 87 84 83 86 degrees
distance to tj max-64 64 64 64
sensor movement 21 19 19 21 for core 0 1 2 3 respectively.
vickybat is offline
Old 03-12-2009, 10:29 AM   #16 (permalink)
Super Moderator
asingh's Avatar
You temperatures are on the high side. But still want to see the screen shot.
Embed Procedure:
1. Make a screen shot.
2. Save it as .JPG.
3. Upload to imageshack (resize to 640x480). Imageshack will give the option.
4. Use the upload utility (as screen shot below), and embed the link(direct image link).
How to get direct image link from uploaded Imageshack image:
1. Right click on image.
2. Choose 'share it'
3. Pick the direct image link onto your clipboard.
Upload procedure:
Hope this helps.
asingh is offline
Old 03-12-2009, 10:39 AM   #17 (permalink)
vickybat's Avatar
vickybat is offline
Old 03-12-2009, 10:50 AM   #18 (permalink)
vickybat's Avatar
after reseating the heatsink the humming sound is gone.here's the results 10 min after first test
vickybat is offline
Old 03-12-2009, 10:51 AM   #19 (permalink)
Super Moderator
asingh's Avatar
Okay...sorry if I did not make it clear earlier. Make a screen shot of 'just' the RealTemp application. Cannot read the numbers. Sorry to hack at you so much..!
asingh is offline
Old 03-12-2009, 10:53 AM   #20 (permalink)
vickybat's Avatar
you can now cause i have increased the resolution
vickybat is offline
Old 03-12-2009, 11:39 AM   #21 (permalink)
Super Moderator
asingh's Avatar
OKay, thanks. Those temperatures are on the slight high side. But you can live with it. When you reseated the HSF, did you apply TIM...?
If you are not OC'ing, then I think no need for after market HSF.
asingh is offline
Old 03-12-2009, 01:42 PM   #22 (permalink)
vickybat's Avatar
Smile Re: HSF for core i5
@ asigh I ran the test today again but got slight lower temps.Tj max was set at 90 and to work on 4 threads option was set.Posting the screenshot.
No i didnt apply tim after reseating cause i dont have any but the humming sound is gone after reseating.What should optimum stress temp for i5
vickybat is offline
Old 03-12-2009, 02:13 PM   #23 (permalink)
Super Moderator
asingh's Avatar
They are fine..as I said. Slightly high. Apply TIM, you should get 2-3 degrees lower. That is the best the stock HSF will do.
asingh is offline
Old 03-12-2009, 09:15 PM   #24 (permalink)
vickybat's Avatar
If i don't apply any TIM will it harm the proccy or any components.
Dont have any quality ones available here.
I've heard of artic silver.Is it good?
vickybat is offline
Old 03-12-2009, 10:14 PM   #25 (permalink)
Super Moderator
asingh's Avatar
The TIM insures that the HSF and the CPU head make a perfect join, else at times there are air pockets.
Arctic Silver is nice, CM Nano Fusion is nice too.
asingh is offline
suggest a good cabinet for core i5 within 2k vickybat Hardware Q&A 30 18-11-2009 12:09 PM
core i5 review roundup (from benchmark sites) desiibond Reviews 4 02-11-2009 07:36 AM
New Intel Core i7, i5 and i3 pricing and specs leaked topgear Technology News 12 18-08-2009 09:29 AM
Linux Modem Drivers For Conexant HSF Soft56 Speakerphone mAYHEM Open Source 1 15-02-2005 01:46 PM
- by bhaskar
