Old 01-12-2009, 10:14 AM   #1 (permalink)
Arrow External TV tuner card.....Please help.
I have 15" CRT monitor to whom I want to connect external TV tuner card.
The TV tuner must be standalone type & requires only the MONITOR. Also it should support 17" or 19" LCD which I will buy in future.
Please suggest some good external TV tuner card under 2K.
Also tell about your experience if you have used it.
I have seen VideoMate v150 & AVerTV Box Genie l M075 in MARKET @ Mumbai.
Thanks in advance.
Mr.Digital is offline
Old 01-12-2009, 11:11 AM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: External TV tuner card.....Please help.
I am using Umax Tvision External TV tuner card. It should be sufficient to you. It will also run on 22". So futureproof also.
Blogging at:
Technostarry
saqib_khan is offline
Old 01-12-2009, 11:25 AM   #3 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: External TV tuner card.....Please help.
almost all external requires only monitor no PC is needed in external
it is call External TV Tuner Box (not card, card is internal one)
u can easily get external tv tuner under 2K
even rs. 800 one run on 15" to 19" but resolution (i.e. clarity) is big problem in cheap one
before buying just check its resolution if it can support 1024 x 768 or higher than it can run perfectly on 19" LCD
if need cheap check for GADMEI
yes as suggested by saqid - Umax Tvision is nice one
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 01-12-2009, 01:01 PM   #4 (permalink)
Please mention the MODEL no. & how about its quality of image & detection of channels?
Old 01-12-2009, 09:28 PM   #5 (permalink)
I M A *STAR*
saqib_khan's Avatar
Quality of Image is very good. I am using it for Samsung 2233. Dont know about detection of channels, because I am using it for DishTV.
Blogging at:
Technostarry
Old 04-12-2009, 02:56 PM   #6 (permalink)
TV Tuner CARDS
External
Gadmei TV 3488E @ Rs. 950
Gadmei TV 3820E @ Rs. 975
Umax Tvision LCD TV Tuner card @ 1.8k
Internal
PixelView Play TV Pro 3 @ 1.2k
Pixel View PV-M54500 @ 1.4k
Avermedia Super 007 @ 1.6k
This might help..
f123 is offline
Old 04-12-2009, 03:18 PM   #7 (permalink)
Super Moderator
asingh's Avatar
Do internal TV tuner cards, load the system. Or is it just a signal which is routed via the board to the monitor..?
asingh is offline
Old 04-12-2009, 05:36 PM   #8 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^Didnt understood the question. For internal TV Tuner cards, its necessary for the OS to load and then you double click the software which is supplied by the tv tuner. In short, for internal tv tuner card, you have to start the software.
And for external, you even dont require to start the CPU.
Blogging at:
Technostarry
Old 04-12-2009, 05:52 PM   #9 (permalink)
Super Moderator
asingh's Avatar
Does the internal TV tuner card stress the system (CPU/GPU), when a signal is passed from the board to the monitor..?
asingh is offline
Old 05-12-2009, 03:40 PM   #10 (permalink)
I M A *STAR*
saqib_khan's Avatar
No it doesn't do anything like that. I haven't found any decrease in speed after installing this tv tuner.
Blogging at:
Technostarry
Need Suggestion on TV Tuner Card emmarbee Hardware Q&A 6 20-11-2009 06:59 AM
TV Tuner Card and LCD Monitor just like a normal LCD TV lahratla TVs / Monitors 1 27-08-2007 07:26 PM
Apple TV nepcker QnA (read only) 33 30-03-2007 12:49 PM
Buying a TV Tuner Card abhijeet_ghosh QnA (read only) 11 05-07-2006 01:38 PM
- by bhaskar
