Old 27-11-2009, 10:21 PM   #1 (permalink)
Democracy is a myth
rhitwick's Avatar
Unhappy *URGENT* Display not coming...help
Guys, my PC is not showing display since morning.
>Procy and GFX card fans are working.
>Changed RAM slots (no result)
>RESET CMOS (no result)
Config:-
Q6600
Abit IX38Quad GT
4GB Gskill
eVGA 8800GT
AOC 917VW
CoolerMaster 600W SMPS
Help plz, I don't even have an onboard display....
Plz, guys, do something
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 27-11-2009, 10:30 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: *URGENT* Display not coming...help
Okay....
1. Pull out the GPU.
2. Blow a few times hard, into the PCI.Ex16 slot to remove all dust.
3. Reseat it.
4. Pull out all PSU connectors and put them back -- firmly and tight.
asingh is offline
Old 28-11-2009, 01:41 AM   #3 (permalink)
Crowman
Krow's Avatar
rhitwick do this before you go to konkan man!
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 01-12-2009, 11:15 AM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Unhappy Re: *URGENT* Display not coming...help
Well, I'm grounded......
My PC is dead and I'm clueless......
Its just not working...I think my GFX card is gone...
rhitwick is offline
Old 01-12-2009, 11:22 AM   #5 (permalink)
The Sorcerer's Avatar
*points towards the psu*
You will have to get a better psu and see if the system boots. If the system boots, you need to run certain stress testing software to check if all the hardware is stable on stock. If a hardware is instable, assuming its not visibly damaged, give it for RMA. Do note that certain problem do remain dormant and undetected even after stress testing. It is therefore a healthy practice to get a good psu first.
Hardware BBQ
The Sorcerer is online now
Old 01-12-2009, 11:31 AM   #6 (permalink)
Democracy is a myth
rhitwick's Avatar
If its PSU, then what are the signs of it?
Exact signs plz, I'm too tired to decipher codes...
rhitwick is offline
Old 01-12-2009, 11:32 AM   #7 (permalink)
^^ Read up.
Hardware BBQ
Old 01-12-2009, 11:32 AM   #8 (permalink)
Super Moderator
asingh's Avatar
^^..Seems so.
But the OP can try his GPU in another system. To isolate the problem.
asingh is offline
Old 01-12-2009, 11:37 AM   #9 (permalink)
^^ Possibility exists the system would be damaged, or not. Maybe the hardware isnt damaged, just not starting because its not getting enough power, pretty obvious since the ratings on the unit is over exaggerated and the operational temps are overlooked.
If this is the case, rhitwick should consider himself lucky, if not, then he need to keep his fingers crossed that its the problem of the card alone. G skills take 7 business days for usual RMA, not sure about evga. Abit doesn't exist anymore so distributors will repair it just for the sake of getting it working again.
My point is, if the OP forces the system to boot with this psu, he might end up damaging further.
Hardware BBQ
Old 01-12-2009, 11:41 AM   #10 (permalink)
Democracy is a myth
rhitwick's Avatar
^^ Read up.
My bad, when I quoted, it was showing only that line...
I think my system boots (or starts)...
Procy fan spins
HDD vibrates (means its spinning)
Tell me one thing, if my PSU is gone, would it power up my system?
Because, when I press the power button on my cabinet, all MOBO lights come to life, BIOS POST code is displayed, all fans spin...
Only the fcuking monitor doesn't get display.
It stays as black
rhitwick is offline
Old 01-12-2009, 11:42 AM   #11 (permalink)
Super Moderator
asingh's Avatar
Gosh...! Is the CoolerMaster 600W SMPS really that bad. How much can it pump out, and be at safe levels...?
asingh is offline
Old 01-12-2009, 11:46 AM   #12 (permalink)
Democracy is a myth
rhitwick's Avatar
This is frightening...
rhitwick is offline
Old 01-12-2009, 11:46 AM   #13 (permalink)
Crowman
Krow's Avatar
In my friend's system, the same happened. It was a RAM problem with him. The display used to show Check Signal Cable or Analog/Digital ??? . We got the RAM replaced and the thing booted just fine.
Krow is offline
Old 01-12-2009, 11:46 AM   #14 (permalink)
Super Moderator
asingh's Avatar
Procy fan spins
It stays as black
Then I guess, try your system on another monitor, and eliminate the possibility of a bad monitor.
Then progress to PSU check, the GPU, RAM. Last could be motherboard.
asingh is offline
Old 01-12-2009, 11:48 AM   #15 (permalink)
Crowman
Krow's Avatar
rhitwick You could ask Anorion for help. He may not be free, but you can always visit his place, as and when he is free.
Krow is offline
Old 01-12-2009, 11:50 AM   #16 (permalink)
Super Moderator
asingh's Avatar
^^ Krow, update your signature for christ's sake...! High time..!
asingh is offline
Old 01-12-2009, 11:57 AM   #17 (permalink)
Yeah. If a hard drive's pcb board is damaged the system will boot for a second and shut down asap- unless you unplug the sata/ide cables and the hdd connector. Depending on the damage on the rams, it would boot till it hits a certain load and gives BSOD or not boot the system at all. If nothing is getting displayed on the screen that mean graphic card can be damaged.
You can try connecting the pc to your screen if you want to and see if that helps to rule out the possibility. I strongly go against using another graphic card however.
The word is "obsolete". Here's CM extreme series:
CM series 500w is a quality degraded version of seventeam 500w. CM extreme 600w and cm extreme 500w are technically the same. Extreme series come with passive pfc and with no pfc- PCAR and PCAP. the passive pfc version comes with 2 types of heatsinks- copper and aluminium. Unfortunatly aluminium had problems and damaged the system and quietly introduced the copper version. But you get the aluminium ones are sold a lot over here. Long story made short- cm gets rid of their stuff in countries like India because majority of the buyers are either completly ignorant, fanboys or sadly don't get access to relevant information, mainly because completely ignorant people suggest based on fanboyism and limited experience.
This is coolermaster- when something gets sold a lot, they decrease the quality of the product. Don't be suprised, older cm 690 with front grills don't rust, but the newer ones, depending on the area, the front punched out tinsheet grill will rust due to moist. Word of advice to cm 690 users, dont wipe the front bezels with moist cloth or (as some people say it) "slightly" wet cloth.
Hardware BBQ
Old 01-12-2009, 12:00 PM   #18 (permalink)
Democracy is a myth
rhitwick's Avatar
I already did, and he visited me yesterday.
He's a gr8 guy, came directly from office.
Really appreciate his help...
Why???
rhitwick is offline
Old 01-12-2009, 12:01 PM   #19 (permalink)
Super Moderator
asingh's Avatar
Yea, seems like the POST is failing. Some damaged part.
I wipe my CM690 cabinet like that...groaaaaaaaaan...!
Posted again:
Why???
So we all know, who has what.
asingh is offline
Old 01-12-2009, 12:09 PM   #20 (permalink)
Democracy is a myth
rhitwick's Avatar
@Sorcy, dude, I don't know where do u stay, but if u were near by, I would have landed ur home with my cabby...
Hmm, so u say, it might be PSU...
I was planning to try another GFX card today, may be another RAM too...
Now I think I should just send PSU to shop...to test...or should I try a diff PSU at home then decide?
(ab, spare PSU kaha se milega??? )
rhitwick is offline
Old 01-12-2009, 12:18 PM   #21 (permalink)
I live in bandra west. Never been to Thane . Just been to a stop after nerul to pickup my lian li case.
Its best if the shop keeps get the psu checked. But I don't know if they really check. Their defination of checking is usually plugging in and see if it boots or checking with voltage checker. Just how many people test the system to be 100% stable by using stress testing softwares and using oscilloscopes to check the ripple on the psu unit?
Nevertheless, this is a good option you have.
Hardware BBQ
Old 01-12-2009, 02:36 PM   #22 (permalink)
Courage to Know
Anubis's Avatar
Initially did it shutdown by itself some few days ago when this happened ?
If that's the case then it must be PSU.
Else its the RAM
Anubis is offline
Old 01-12-2009, 03:03 PM   #23 (permalink)
Democracy is a myth
rhitwick's Avatar
Else its the RAM
Nope, it never did.
Eventually, there was never an abrupt restart, BSOD, shut-down, freeze-up...
This is the first time it refused to boot and since then its not booting......
rhitwick is offline
Old 01-12-2009, 03:49 PM   #24 (permalink)
Fullbring
Zangetsu's Avatar
if u get a beep sound when booting then RAM is fine...
Proccy is fine
BIOS is fine.....
HDD id fine....
Have u checked the HDD is detected or not go to BIOS & check r all components detected..
Check with other PSU...but i doubt coz PSU fan is spinning ryt...
Zangetsu is offline
Old 01-12-2009, 03:54 PM   #25 (permalink)
Democracy is a myth
rhitwick's Avatar
Proccy is fine
BIOS is fine.....
HDD id fine....
No beeps......no beeps, strange, but no beeps. Never ever it beeped.
Can't go to BIOS, as display is not showing.
And, ya PSU fan is spinning.
rhitwick is offline
Old 01-12-2009, 03:57 PM   #26 (permalink)
Not entirely true. If it beeps, it just means that the ram is stable enough to boot from POST. Being stable for booting is one thing, but being stable for using the system without any worries is just another ball game and can be only be proven stable when a memtest 86+ tests are conducted for 6 hours flat atleast.
No it doesn't work that way mate. Just because a psu fan is running properly, doesn't mean the psu is. The fan on the psu is connected on the 3 pin connector on the psu's pcb board- not via molex connector.
Hardware BBQ
Old 01-12-2009, 04:06 PM   #27 (permalink)
Fullbring
Zangetsu's Avatar
^ if a we get a beep then it means RAM is detected & proceed 2 next phase....
but he didnt get ne beeps...
Hey rithwick when u switch on u say 'beep'
only option left is check with other PSU
Zangetsu is offline
Old 04-12-2009, 05:49 PM   #28 (permalink)
hey guys.. i just bought a sapphire 4850 512mb version and a coolermaster extreme 500 (the one that comes 4 arnd 2.8k). Now i installed the psu, card, installed windows 7 (32 bit) formatted my hard-drives... i did not connect my display to the gpu till then.It worked on on-board graphics. But now when i go to install the ati software, it does not detect my gpu. nor does the add new hardware wizard. what am i doing wrong?
(btw sorry for butting in rhit wick)
sagsall4u is offline
Old 04-12-2009, 05:55 PM   #29 (permalink)
Super Moderator
asingh's Avatar
Is the VGA disabled from the BIOS. Which motherboard you have..?
asingh is offline
Old 04-12-2009, 07:43 PM   #30 (permalink)
Democracy is a myth
rhitwick's Avatar
Have u provided to the card?
It would require external power....
Check...
rhitwick is offline
Display Not Coming Always nithishr Hardware Q&A 5 22-11-2009 12:00 PM
One Giant Command Line MetalheadGautham Open Source 23 24-05-2008 02:31 AM
Bet you never know this secrets ashish_patel Tutorials 34 14-01-2008 09:44 AM
Windows Sortcuts and commands rajat22 Tutorials 6 27-07-2007 04:17 PM
Opera 8.01- Final Released Curious Guest QnA (read only) 6 23-06-2005 11:18 PM
- by bhaskar
