Old 26-11-2009, 06:02 PM   #1 (permalink)
Kalyan's Avatar
Default need info abt APC UPS.
This might be a noob qn. but I don't understand the complete operation of my APC ups. I am using APC UPS ES 650. there is only one button, two LEDs, one reset button. pls clear me if what I am doing below is normal or not.
1) When the ups is off and is charging, there is no indication. The indicator light is on only when the ups is on..
2) I normally press the button once, hear a short beep and then, the amber light flashes for some time (I think this is self test. does it have to run every time?). The same to switch the ups off.
3) As per the manual, holding the button for 10 sec would switch to program mode to choose high / med / low levels.
4) Is there a way to switch the ups on when there is no power..
I am a bit confused because, the same button is being used for various operations and APC doesn't provide the operation in the manual. only trouble shooting is listed.
Thanks a lot..
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is offline
Old 26-11-2009, 08:30 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: need info abt APC UPS.
Well I found this. It tells how the sensitivity can be selected. Pretty straight forward.
I do not think so, it can be switched ON, if power is OFF.
asingh is offline
Old 26-11-2009, 10:57 PM   #3 (permalink)
finding a way out !!!
press the switch for some time wen there is no power to start the computer.
rest all things u stated is correct and dats how it works.
contact for RS premium account
fallin_a is offline
Old 26-11-2009, 11:04 PM   #4 (permalink)
Super Moderator
asingh's Avatar
^^ The UPS will not power on, if there is no feed from the back.
asingh is offline
Old 27-11-2009, 02:12 PM   #5 (permalink)
^^^ i thought he asked how to on the ups when ac power is not available provided bkup is there.
fallin_a is offline
Old 27-11-2009, 03:44 PM   #6 (permalink)
Super Moderator
asingh's Avatar
And that is what I told him. If there is no electricity in the house, and he tries to turn the UPS 'on', it does not turn on. At least my APC 1.1KVA does not.
It turns ON when there is power feed from back, and if the power feed is cut off, then it starts to provide back up.
asingh is offline
Problem With SMPS Or UPS Beta Waves Hardware Q&A 17 30-08-2008 09:02 PM
error Installing fc5:partion table unreadable gary4gar Open Source 16 21-09-2006 07:38 PM
SymbOS malware info ALL!! neerajvohra Mobiles and Tablets 11 05-09-2005 07:50 PM
APC UPS Model Number undecided - Final decision awaited...!! sincereheart QnA (read only) 3 25-07-2005 01:34 AM
need info abt this.....urgent!! legolas QnA (read only) 6 24-07-2005 08:48 PM
- by bhaskar
