Old 26-11-2009, 05:57 PM   #1 (permalink)
prabhu.wali
prabhu.wali's Avatar
Unhappy lite off
i m using a moser baer writer,i tried burning a dual layer dvd from the same make but encountered a power caliberation errorwot could be the prob??????
prabhu.wali is offline
Old 26-11-2009, 09:53 PM   #2 (permalink)
CA50's Avatar
Default Re: lite off
Clean ur writter lens, tighten the power n data cables, check if ur PSU is underpower. N lastly try some other band media also burn @low speed
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Flash lite palyer for SE mobile?????? bravo007 Mobiles and Tablets 2 15-10-2009 09:06 PM
How 2 Remove Nag Screen from Diskeeper Lite anandk Tutorials 3 27-02-2007 07:46 PM
Winamp 5.22 - Pro/ Full/ Lite/ Bundle rajat22 Software Q&A 3 01-06-2006 03:04 PM
Winamp 5.12 Pro/ Full/ Bundle/ Lite rajat22 Software Q&A 6 11-12-2005 10:25 AM
Should I install AutoPatcher XP after WIN XP SP2 //siddhartha// Software Q&A 5 21-02-2005 02:40 AM
- by bhaskar
