Old 26-11-2009, 01:13 PM   #1 (permalink)
CA50's Avatar
Angry UPS problem
hi friends 2day my UPS gave up
It wasn`t giving backup, so i opened it, and found that the negative terminal of the battery broke into two because of corrosion.
Is there and possiblity of getting its life back?
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 26-11-2009, 01:29 PM   #2 (permalink)
CA50's Avatar
Default Re: UPS problem
Oops................
| Nokia 2700c |
CA50 is offline
Old 26-11-2009, 01:51 PM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
I'll say get a new UPS or Replace it if it's under warranty instead of changing the battery. Look for APC ones. It'll cost u 2.5k approx.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 26-11-2009, 02:20 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Is any part of the terminal still attached to the battery unit..?
asingh is offline
Old 26-11-2009, 05:00 PM   #5 (permalink)
CA50's Avatar
Red face Re: UPS problem
no actually the terminal is now a bit inside da seal. I am thinking of soldering it, hope it wil woke.
| Nokia 2700c |
CA50 is offline
Old 26-11-2009, 05:01 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Ya..you could. Soldering should work. Sounds like fun work.
asingh is offline
Old 26-11-2009, 05:04 PM   #7 (permalink)
CA50's Avatar
what VA??
My ups is 2.5yrs. Battery is fine just terminal problem
Posted again:
yeah fun works, but da soldering area is deep inside da seal
| Nokia 2700c |
CA50 is offline
Old 26-11-2009, 05:36 PM   #8 (permalink)
Super Moderator
asingh's Avatar
I guess the battery electrolytes are in a deep layer. So you should be able to melt the seal a bit, and get to the contact. Then try to solder. Initially you can try a hot-wire. Just attach a wire (wrap it), and see if the contacts are working. Then try the solder...
asingh is offline
Old 26-11-2009, 09:57 PM   #9 (permalink)
CA50's Avatar
Yeah the end contact is visible, i checked with MM, da batt was fine.
Fnds hav u got anyidea how to melt or break da seal
| Nokia 2700c |
CA50 is offline
Old 26-11-2009, 10:03 PM   #10 (permalink)
Crowman
Krow's Avatar
VA means Volt-Ampere IIRC.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 26-11-2009, 10:11 PM   #11 (permalink)
Simply a DIGITian
^^ Hehhehhe. He knows what VA means. He's asking about how much VA he shud luk for....!!
Luk for normal 600VA. I'm not so sure.
Well see what other member suggests. As ur UPS battery is f9 u can repair it also as u r thinking off....!!
Old 26-11-2009, 10:13 PM   #12 (permalink)
Crowman
Krow's Avatar
Damn, I should read entire threads rather than just the last few posts. Almost like watching a movie from after the interval.
Krow is offline
Old 26-11-2009, 10:38 PM   #13 (permalink)
Simply a DIGITian
lolzzzzz
Old 26-11-2009, 10:55 PM   #14 (permalink)
Super Moderator
asingh's Avatar
1. Are you able to hot-wire the exposed battery contact to the UPS circuit, and check if it is working fine.
2. What you checked with VM -- the continuity of the battery power.
3. You can melt the seal, but taking any hot rod (screw driver heated on fire) and push it in. Or do it with a hot solder (I do that), and immediately wipe the melted plastic off the solder using a cloth.
asingh is offline
Old 27-11-2009, 09:24 AM   #15 (permalink)
CA50's Avatar
the terminal is deep, the multimeter probe touched the end contact n i measured the voltage reading, it was 12.03v so batt is alive. And abt da seal i wil try it right away. I wil post its pics, currently i m using cell phone 4 browsing, so hav patience.
@krow, whats offtopic man?
| Nokia 2700c |
CA50 is offline
Old 27-11-2009, 09:40 AM   #16 (permalink)
CA50's Avatar
Here is da pic of my ups batt
| Nokia 2700c |
CA50 is offline
Old 27-11-2009, 10:07 AM   #17 (permalink)
Super Moderator
asingh's Avatar
^^ Melt it like I told you. Use a extremely hot screw driver. Heat it over the gas, and start to probe.
It will get messy, and might render the screw driver useless. If you realize that the electrolytic sealant has been breached, carefully dispose the battery. Its toxic. Do not just put it in the home dust bin.
Do this 'operation' on the floor, on top of some old news papers. So if something leaks, will not cause harm. Do not let the liquid touch your skin. Best of luck. Have fun.
asingh is offline
Old 27-11-2009, 11:47 AM   #18 (permalink)
CA50's Avatar
Thanks asigh, i tried breaking off da seal n soldering, no electrolyte got leaked, here is the pics of da batt, hope it wil work,
do u think da batt blow when working?
| Nokia 2700c |
CA50 is offline
Old 27-11-2009, 12:05 PM   #19 (permalink)
Super Moderator
asingh's Avatar
Hey..that is a good job. It should work.
I would suggest to use it like this:
1. Attach it to the UPS circuit.
2. Let it charge for a while. (Do not hook up the computer)
3. Then discharge the battery by hooking up some low power devices. Say a 100W household bulb, for an hour.
4. Charge it up again. Verify it with the VM.
5. If all fine, hook it back.
Put some tape on the solder. Great job....!
asingh is offline
Old 27-11-2009, 02:23 PM   #20 (permalink)
CA50's Avatar
Thanks buddy i will try it man, n post my comments. Thanks 4 ur replies
| Nokia 2700c |
CA50 is offline
Old 29-11-2009, 07:50 PM   #21 (permalink)
CA50's Avatar
Smile Re: UPS problem
thank u guys, i assemble my ups 2day now its fine, here is it
My pc is running happily, also getting backu as usual.
| Nokia 2700c |
CA50 is offline
Tech com Ups Problem Krish_88 Hardware Q&A 2 07-01-2008 01:43 PM
UPS or PSU causing problem? ring_wraith Hardware Q&A 13 01-01-2008 06:03 PM
SEVERE Overheating Problem... akash_bhavsar Hardware Q&A 6 17-11-2006 11:11 AM
GRAVE SYSTEM PROBLEM GunshotSilence QnA (read only) 2 11-09-2005 04:33 PM
UPS and downs : ups restarts pc !!! klinux QnA (read only) 2 26-12-2004 12:22 AM
- by bhaskar
