Old 26-11-2009, 01:09 AM   #1 (permalink)
Default help in buying a laptop
hi guys
need your help in buying a laptop. need the suggestion for a model
need to have an ATi or a nVIDIA graphics card for occasional gaming like.
Should withstand rough use( i will use the laptop for around 15-18 hours per day)
OS not really necessary as I plan to use Karmic.
I know that a desktop would be better for me, but i travel a lot.
simoncherian is offline
Old 26-11-2009, 09:49 AM   #2 (permalink)
Team Digit
r4gs's Avatar
Default Re: help in buying a laptop
You haven't given a budget.
Check out Dell's laptops from the Dell website. You can customize the laptop as you require it to suit your budget and requirements.
If you want one specifically for travelling, try a 13" screen, otherwise 15" should do.
Core i5 2400; 8gb ddrIII 1600mhz; nVidia GeForce GTX465 1gb; seagate 1tbx3; Seasonic S12D 750; MSI H67MA-E35;
r4gs is offline
Old 26-11-2009, 10:24 AM   #3 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
dude mention a budget only then can we give suggestions
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 26-11-2009, 10:54 PM   #4 (permalink)
sorry bout that guys.
my budget is around 50k
had a hp pavilion dv2855. worked perfectly for 1.5 years. extremely rough usage. used to get heated up pretty bad. motherboard fried now. 5 days out of extended warranty.
the thing is that as i said i will use the laptop for around 15-18 hours a day and do a spot of gaming too and really dont want to get the motherboard fried again due to excess heat production.
Old 26-11-2009, 11:56 PM   #5 (permalink)
Team Digit
r4gs's Avatar
HP has been having that problem a lot. 2 of my friends had the same problem. Now the warranty ios over and HP is asking for about 27k to replace motherboard.
Try the Dell Inspiron15 or studio series. Customize it to your need. I think it comes with a gaphics card, or you can add one.
In fact, just go to the Dell website and take your pick in your budget range. You are sure to find the configuration you desire in your budget.
In my experience, Dell offers the best value for money in terms of configuration. Also, support is very good.
My friend's 6 cell battery gave up so they gave a 9cell free.
Sony is highly overpriced.
r4gs is offline
Old 27-11-2009, 02:41 AM   #6 (permalink)
ok
i will suggest HP dv6-2005ax ... it has ati hd4650
i am using it currently. its awesome.. doesnt heat up & i use it for like 24 hours a day.
Old 27-11-2009, 03:09 PM   #7 (permalink)
Check out Dell Inspiron / XPS
PraKs is offline
Old 27-11-2009, 03:14 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
1) Get Dell Studio 15
2) Buy one laptop cooling pad which costs around 1.5k-2k (cooler master) and saves 30k-50 down the line
desiibond is offline
Old 27-11-2009, 05:03 PM   #9 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Originally Posted by ssk_the_gr8 View Post
ok
I second that, 3 of my friends have this laptop running Windows 7. No problems whatsoever. Awesome gaming performance for the price (45-47k).
[IMG]http://www.thinkdigit.com/forum/data:image/gif,GIF89a%12%00%12%00%B3%00%00%FF%FF%FF%F7%F7%EF% CC%CC%CC%BD%BE%BD%99%99%99ZYZRUR%00%00%00%FE%01%02 %00%00[IMG]http://www.thinkdigit.com/forum/data:image/gif,GIF89a%12%00%12%00%B3%00%00%FF%FF%FF%F7%F7%EF% CC%CC%CC%BD%BE%BD%99%99%99ZYZRUR%00%00%00%FE%01%02 %00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%0 0%00%00%00%00%21%F9%04%04%14%00%FF%00%2C%00%00%00% 00%12%00%12%00%00%04X0%C8I%2B%1D8%EB%3D%E4%00%60%2 8%8A%85%17%0AG*%8C%40%19%7C%00J%08%C4%B1%92%26z%C7 6%FE%02%07%C2%89v%F0%7Dz%C3b%C8u%14%82V5%23o%A7%13 %19L%BCY-%25%7D%A6l%DF%D0%F5%C7%02%85%5B%D82%90%CBT%87%D8i7 %88Y%A8%DB%EFx%8B%DE%12%01%00%3B[/IMG]
Posted again:
^^ This forum is hopeless, cr@p junk gets appended to the post sometimes, grrrr.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 30-11-2009, 04:49 PM   #10 (permalink)
Ignorance is BLISS !!
Smile Re: help in buying a laptop
U can use HP pavilion DV6-1152TX.
I am currently using it and have no probs whatsoever with it.
Specs:
4GB RAM
500GB HDD
512MB Graphics
16" 720p HD Screen
Price was 53K incl taxes during october....
rajkumar_personal is offline
Old 30-11-2009, 05:39 PM   #11 (permalink)
thank you for the suggestions guys.
btw isnt the HP dv6-2005ax having an AMD processor? doesnt that heat up a lot?
also i had gone to a local shop to ask about the studio 15 and he was telling me to go for the hp probook after i told him that i use the laptop a lot. that apparently had a 512 mb ati dedicated grahics. dont remember the chipset though.
also went to the dell site and wanted to know the difference between a studio 15 and say a vostro or inspiron which have been configured to my needs.. the other 2 are cheaper for the same config i think.
Old 30-11-2009, 06:19 PM   #12 (permalink)
that is an old myth that amd processors heat up...
the new turion II (45nm) does not heat up. I'm using it currently.
u can go for it without any doubt...
Old 30-11-2009, 06:23 PM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
the older athlon x2 mobile used to run bit hot bt he new turion x2 isa rock solid processor. you can go for it.
Old 04-12-2009, 05:59 PM   #14 (permalink)
Hi friends I too need help in buying a laptop. I am student of mechanical engineering.There will be CAM,CAD etc.Suggest me a suitable laptop .My budget is 50k. Thanks.............Amith
vardhan is offline
Old 04-12-2009, 06:56 PM   #15 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@vardhan, look at Dell Studio 15 and Acer 5739G.
Old 04-12-2009, 09:57 PM   #16 (permalink)
Thanks a lot desiibond
vardhan is offline
Old 05-12-2009, 11:47 AM   #17 (permalink)
Had you mentioned the budget, it would have been easier for us. But as far as rough use is concerned, DELL scores far better as compared to others, even HP, for instance................., as far as my own experience is concerned. But for that, I would suggest you to get studio laptops. Inspirons are cheaper but studios are of better quality than the formers, and I hope, will be able to withstand rough use persistently.....
Machine is offline
Old 07-12-2009, 11:04 AM   #18 (permalink)
what is the difference between dell inspiron and studio?
vardhan is offline
Old 07-12-2009, 12:37 PM   #19 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Studio comes with a better build and better processr and GPU options.
Old 08-12-2009, 11:21 AM   #20 (permalink)
raaj_bharath
Posts: n/a
is it possible to build our own laptop-like we buy barebone laptop chassis, then add our choice of processor , ram , mobo etc . .
i havebeen thinking about this for long but havent put it into action yet .
what do you people say ?
Old 12-12-2009, 11:49 AM   #21 (permalink)
apricot
Posts: n/a
@simon - hey nice to know that you want a gaming laptop. My suggestions would be go for a dell studio 15 in case budget is an issue. In case money is not an object then why not try the Alienware series of laptops? But then it would be much easier to answer your question in case u mention your budget.
Old 15-12-2009, 01:28 PM   #22 (permalink)
try hp dv6 1319tx.
here are the specs
HP Pavilion dv6-1319TX Portable:
Specifications
Model
• HP Pavilion dv6-1319TX
• HP Imprint – Espresso Pattern
Microprocessor
• Intel Core2 Duo Mobile Processor T6600 (2.2 GHz)
• Enhanced SpeedStep Technology
• 800 MHz Front-side Bus Speed
Cache Memory
• 2 MB Integrated L2 advanced transfer cache
Chipset
• Intel PM45 Express Chipset
Memory
• 4 GB PC3-8500 DDR3-1066 (8533 MB/s)
• 2 SODIMM Slots (Expandable to 8** GB with discard)
Hard Drive
• 500 GB Serial ATA
• 150 MB/sec @ 7200 RPM
• HP ProtectSmart HDD Protection
8X SuperMulti Drive with DL
• LightScribe Technology
• DVD+RW/+R Writer
• DVD : 8X + write; 4X + re-write; 8X DVD read
• DVD+R DL : 4X read; 2.4X write
• CD : 24X write; 16X re-write; 24X read max speed
• DVD-RAM : 5X read and write
Video Graphics
• ATI Mobility Radeon HD 4650
• 1 GB Dedicated Graphics
• Up to 2303 MB TAG* memory (as allocated by Windows 7)
• Supports DirectX 10.1
BrightView Display
• 15.6” LED Backlit Widescreen
• Diagonal Size – 15.6” (39.62 cm)
• 1366 x 768 HD (720p)
• 16:9 True Wide Aspect Ratio
• BrightView Screen Audio / Speakers
• SRS Audio
• High Definition Audio
• Altec Lansing Stereo Speakers
Interactive Volume Controls
• Volume control strip
• Mute button
Communication
• Integrated 10/100/1000 LAN
5-In-1 Digital Media Reader
• Secure Digital, Multi-media card, Memory stick, Memory stick pro and xD picture card
Wireless PAN / LAN
• Integrated Bluetooth 2.0 HP Module
• Integrated Wireless LAN 802.11 b/g
Next Generation - ExpressCard
• ExpressCard/54 slot
Interface
• One HDMI v1.3b with HDCP Key
• eSATA (3 Gb/sec) / USB 2.0 combo Port
• Three USB 2.0 Ports
• One IEEE 1394a Port (4 pins)
• Two Stereo Headphone Jacks
• One Microphone In (Stereo)
• One RJ-45
• One DC Power In
• One VGA Out
• Expansion port 3 – Docking Port
• Kensington Lock Slot
Pointing Device & Keyboard
• Touch Pad with Two way Scroll Zone
• 86 Keys layout; 12 Function Keys
• Fingerprint Reader
Webcam and Microphones
• Integrated Web Camera
• Digital Dual Array microphones
Accessories and Battery
• HP Mobile ExpressCard Remote Control
• 6 Cell Lithium Ion Software
Operating System
• Windows 7 Home Premium(32-bit)
Additional Software
• Motorola SoftStylus
• Adobe Acrobat Reader 9.x
Digital Entertainment / Imaging
• Cyberlink DVD Suite
• HP MediaSmart
HP MediaSmart DVD
HP MediaSmart Music
HP MediaSmart Photo
HP MediaSmart Webcam
• HP Games (Shareware)
• Digital Persona Fingerprint Reader
Security and Maintenance
• 3D Drive Guard HDD Protection
• Norton Internet Security 2009 (Includes 60 days of Live updates)
• Norton Anti-Virus (Includes 60 days of Live updates)
Recovery Kit
• Recovery Disc Creator
Help and Support Centre
• HP Software Updates
Dimensions – (H x W x D)
• 1.33 / 1.60 x 14.90 x 10.15 inches
• Note: Height varies depending upon where on the notebook the measurement is made
• Weight – 2.87 Kgs / 6.34 lbs
AND THIS YOU CAN GET FOR 52k in delhi
wishmaster.dj is offline
Old 16-12-2009, 12:17 PM   #23 (permalink)
i wanted to know if there is any 3G connected netbooks available in the market. sometimes wifi-s are not helpful as it is restricted to one a certain place. anybody know of 3G products?
amit22 is offline
Old 16-12-2009, 12:24 PM   #24 (permalink)
apricot
Posts: n/a
well hello amit. 3G is a good option to choose, but it is limited in the market right now. only dell has it along with Olive. Olive is launching in india in December and would be having the 3G feature. So u can connect anytime anywhere. Olive is in collaboration with Tata Docomo as its ISP. So basically if you make a purchase with this product, Tata Docomo will give you a free plan for 2 years absolutely free. hope this helps.
Old 16-12-2009, 12:27 PM   #25 (permalink)
what are the price specifications and what are the product specs for the two?
amit22 is offline
Old 16-12-2009, 12:52 PM   #26 (permalink)
apricot
Posts: n/a
you can check out the price specifications at :
http://www1.ap.dell.com/in/en/home/n...=dhs&cs=indhs1
for olive the product specs are:
intel atom i.6GHZ
intel 945GSE+82801GBM
Bluetooth enabled
wifi enabled
3G modem integrated
3in1 card reader
1.3 MP
Weights 1.2kgs
rechargeable lithium 3 cell battery
3 USB ports
hope this helps!
---------- Post added at 12:52 PM ---------- Previous post was at 12:50 PM ----------
dell would be costing you 30,000 INR and olive for the same product along with stylish features would be costing you 23,000 INR.
Benefits of Buying a Laptop on Thanksgiving in US ?? raksrules Chit-Chat 5 03-06-2008 11:28 AM
Acer Aspire 4720 Z Laptop Review FilledVoid Reviews 8 11-01-2008 05:06 PM
Buying a new laptop ashwn_acharya Laptops and Netbooks 4 16-11-2006 10:22 PM
Buying Vista Compatible Laptop dragonlord Laptops and Netbooks 8 25-02-2006 10:17 AM
Buying a Laptop Pragna QnA (read only) 14 06-06-2005 01:17 AM
- by bhaskar
