23-11-2009, 08:27 PM
The Master Chief
DVD Writer help needed
Hey guys i have been owning sony dvd writer for 4 years now & finally it seems to have stopped working...it doesn't respond to any cd,scratches come in the disk,cd cracking inside etc...Since its out of warranty now...i need to get a new dvd writable drive soon...So my budget is about 1400-1500 approx..could u guys pls suggest a good dvd drive in the market right now?do i have to tweak my budget...pls help me out in this... thanks
Intel Core I5 2500K,Gigabyte GA P67A UD3 B3,Corsair Vengeance 4gb DDR3,CM430 Cabinet,Corsair VX550W,Razer Cyclosa Bundle,Seagate 250GB,500GB,1TB,MSI 5770 hawk
23-11-2009, 09:15 PM
Gracias Senor
Re: DVD Writer help needed
search is ur companion..many suggestions and debates have already done in this forum.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
23-11-2009, 10:26 PM
Crowman
LG GH22 SATA @ 1.1k.
24-11-2009, 12:12 AM
The Master Chief
Ahh i did initially search for dvd writers for the first few pages..couldn't find the appropriate one..My bad...Next time will read more pages & see it myself..Atleast i don't need to create a new thread everytime..
Posted again:
hmm never used an lg drive before..hows the service??just did a google search..seems to be 22x..Need a product which will last for 2-3 years..are their products reliable?
Reason: Automerged Doublepost
24-11-2009, 08:51 AM
Crowman
Its luck basically. Your favourite brand may die within 1.5 years, while a brand you dislike may last for 2-3 years for me. Get LG/Samsung and hope it lasts.
24-11-2009, 11:00 AM
Gracias Senor
thnx for understanding and also to take these type of comments sportively.
One suggestion I can make here, samsung gives the tray problem and even sony does the same. experiencing the same with these brands.
as krow said, try LG/Benq/Lite-on(I believe this is also sony, but not sure)
24-11-2009, 11:57 AM
Simply a DIGITian
I wud recommended LG. I have been using it for more than 3yr's without any problems.
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
25-11-2009, 12:53 AM
The Master Chief
Thanks Krow,dreams & krishnandu.sarkar for your help..will definitely look into LG/samsung writers & buy it..Thanks again..
25-11-2009, 08:34 AM
Stick to 6x speeds for substandard (including moser baer) and 8x for good disks.
25-11-2009, 08:41 AM
Crowman
^Which are the good disks?
25-11-2009, 09:22 AM
never found anything better then sony.
I have tested,creative, LG, Samsung, TLink etc. Still Sony has more life.
25-11-2009, 09:34 AM
I don't why digit, being a tech forum, aren't even basically detailed about model numbers as far as dvd drives are concerned >_>
AFAIK sony 820a is a benq 1670 OEM, I heard samsung sh22f could be crossed flashed. Verbatims are good and better than moser baer. sony has pretty good scans but lower than verbatim and bit better than moser baer- atleast the sony discs that I got.
25-11-2009, 09:52 AM
I have been using LG h42n for past 2.5yrs, no problems though. LG's good.
And abt disc i use frontech (cheap) and burn @16x stil those disc r healthy
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
25-11-2009, 10:19 AM
Simply a DIGITian
Lasertras(cheap) and Moserbear(costly) both are very good.......!!
25-11-2009, 07:46 PM
The Master Chief
Thanks,Will keep that in mind next time...Also i had gone to vashi just to ask the price of LG GH22,When i asked him for this particular model,he had a blank look,they showed me one LG model...Is this the only lg dvd model in the market or are there different types?
25-11-2009, 07:49 PM
Crowman
The model number will be apparent on the box. Mostly they sell OEM which is just a plastic wrapping. Try to get a boxed one if you are particular about the model.
25-11-2009, 07:59 PM
The Master Chief
Oh ok,thanks a lot
