Old 23-11-2009, 12:28 AM   #1 (permalink)
Default Building gaming PC for GTS 250 - Please suggest
Hi! I asked this same question a few months ago and was told to wait until the i5 came here. Well, now it is here and I want to get rid of my old noisy PC
I bought a GTS 250 512MB and CoolerMaster Extreme 600W a few months ago and now I am upgrading my system, a 4 year old P4 based. I will mainly use it for gaming and image processing. My current PC can't even give me 100 fps in CS and I won't use my gfx card with it as there is no point to it. Besides, it might not fit into the small cabinet.
I will keep the following from my current system:
-GTS 250 512 MB
-PSU CM Extreme 600W (contrary to its name, it is just passable, it seems)
-LG 19" LCD display with max resolution@1440X900
-160 GB SATA HDD. I might junk the old 80GB though. Will add a new HDD, of course.
-Logitech keyboard and mouse.
My budget is around 25-30k, which should be sufficient
Preferences - I prefer Intel but if the price advantage for an AMD is sufficient, I will go for it too. I am thinking of the following:
- CPU - i7 and its motherboard is still expensive, so I will have to go for the i5. Or should I wait even more?
-A compatible motherboard. Not sure how much it will cost and if I should go for a cheap one or a better one. NO OVERCLOCKING for me!
-A good but cheap cabinet without a good PSU.
-4 GB DDR3 RAM, but if necessary I can settle for a 4GB DDR2 RAM as well.
-A good 500GB/1TB HDD.
If necessary and if budget left, I could also go for:
- A new and cheap DVD-R drive
- Decent speakers (1-1.5k only!) (I have a good Philips headphone for my games, BTW )
- Any other component you think I should buy?
-Please note that the PC will be running in a high temperature, high humidity and high dust environment for a large part of the year.
BTW, will my PSU be sufficient to run a system like this? I think it will be, but still...
I know that this is a long post, but I don't want to make a mistake with this one. I am regretting buying the CM 600W extreme PSU. All suggestions are welcome. Please feel free to make drastic changes to any of my mentioned preferences
bippukt is offline
Old 23-11-2009, 08:32 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Building gaming PC for GTS 250 - Please suggest
CPU: Intel Core i5: 10k-10.5k
Mobo: Gigabyte GA-P55M-UD2 for 7.5k
Transcend DDR3 1333MHz RAM: 2x2Gb: each stick around 2.5k
Cooler Master CM335 : 2.4k or Zebronics Bijli : 1.3k
Seagate 7200.12 or WD Blue 500GB: 2.3k-2.5k or 1Tb for 4k
AMD:
AMD Phenom II X4 955BE: 9.5k
ASUS M4A785TD-V EVO: 7k or MSI 790GX-G65: 7.5k
rest is same.
desiibond is offline
Old 23-11-2009, 10:29 PM   #3 (permalink)
laborare est orare
Cilus's Avatar
rest is same.
tHE PRICE OF PHENOM ii 955 IS LESS than that. It costs u around 8.6k at 10.5k Phenom II 965 is available
Same for the Asus Mobo. It is available at 6.7k
Cilus is online now
Old 23-11-2009, 10:39 PM   #4 (permalink)
Crowman
Krow's Avatar
I am for the i5 config if OP can afford it. I won't pair a GTS250 with an i7 rig.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 25-11-2009, 01:46 PM   #5 (permalink)
Taking the i5 config with CM335 and 500GB HDD, the cost comes at around 28k. If I add a DVD drive as well, it will be around 29k, which is very much within my budget. So, after the upgrade, my gaming system will be:
-CM Elite 335 (Excellent)
-Intel core i5 750 (Excellent)
-Gigabyte GA-P55M-UD2 (Excellent)
-Transcend DDR3 1333MHz RAM: 2x2Gb (Excellent)
-500 GB HDD (Good)
-GTS 250 512 MB (Good enough for 1440X900)
-PSU CM Extreme 600W (Passable, but will do)
-LG 19" LCD display with max resolution@1440X900 (Bad for FPS, racing but will do for strategy game)
-DVD drive (Good)
-Useless speakers but excellent Phillips headphones
I am already drooling with anticipation, now the only thing is to actually go and buy this stuff. I don't think buying it here in Allahabad will be a good idea, as the shops are too expensive. That leaves Delhi as the only feasible option. Any ideas on which Delhi shop might be reliable?
bippukt is offline
Old 25-11-2009, 07:42 PM   #6 (permalink)
Crowman
Krow's Avatar
Better PSU is CM Real Power Pro 460W @ 3.5k or Corsair VX450W @ 4k.
Good speakers are Altec Lansing BXR1121 @ 1.1k
Kingston Ram's have been better for me than Transcend.
Otherwise, config is good.
Krow is offline
Old 25-11-2009, 10:03 PM   #7 (permalink)
Sorry for not mentioning it in my second post, but I already have the PSU and graphics card - not the best choices but nothing can be done now. I might get the speakers though, if I feel like it when in the shop. I don't know about Kingston vs Transcend - they are both good AFAIK, so I will take the cheaper one.
But I still don't know a good PC shop in Delhi - any suggestions?
Thanks for all the help
bippukt is offline
Help: suggest a gaming PC config jobenjoseph PC Components / Configurations 34 24-02-2007 11:18 AM
Suggest Gaming PC configuration budget 75k MaxBombay PC Components / Configurations 5 31-01-2007 03:15 AM
suggest me a good pc for 25k dinesh_mettur Hardware Q&A 4 20-11-2006 07:49 AM
Nokia Software Updater neerajvohra Technology News 16 31-08-2006 02:26 PM
How to make your PC quiet sara2002 QnA (read only) 6 17-10-2004 04:05 PM
- by bhaskar
