Old 20-11-2009, 10:44 PM   #1 (permalink)
Super Moderator
asingh's Avatar
Default Motherboard Boots 3 times
Hi,
Am facing a weird problem. My motherboard makes three attempts to boot then goes to the OS.
1. Attempt one:
All fans and LEDs come on for two seconds. No display to screen. Then all goes off for 2 seconds.
2. Attempt two:
All fans and LEDs come on for 6-7 seconds. No display to screen. Then all goes off for 2 seconds.
3. Attempt three:
Boots to the desktop normally.
This only happens when power is 'cut' to the PSU. Meaning, if the computer is off, but the UPS is 'on' (so there is current in the PSU), and then I power on the system, it is normal. But when I totally switch of supply, turn the UPS OFF, then the above happens.
What could be the reason for this. No issues while working/gaming. No system lock or BSOD/Crash.
Cross posted here.
asingh is offline
Old 21-11-2009, 06:48 AM   #2 (permalink)
Default Re: Motherboard Boots 3 times
This happened to me too....
I took out the CMOS battery for 2-3 min and then placed it back ... Put the RAM in another slot....
This worked out for me ...
abhadi is offline
Old 21-11-2009, 11:02 AM   #3 (permalink)
Super Moderator
asingh's Avatar
Okay will try that. Will be a slight pain though. It is under neath my GPU...
Posted again:
Is your OC'ed
asingh is offline
Old 21-11-2009, 11:21 AM   #4 (permalink)
The Sorcerer's Avatar
Intel p35/45 was reported cold boot problem countless times. Update the bios and see if that prevents. Do note- I said prevent. AFAIK, there were only few cases that this was resolved with only updating bios.
Hardware BBQ
The Sorcerer is online now
Old 21-11-2009, 11:33 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Sure..thanks. I am on the latest BIOS.
asingh is offline
Old 21-11-2009, 11:39 AM   #6 (permalink)
^^ Try booting the system with bios using the rams @ 800mhz. Disable c1e and speedstep.
Hardware BBQ
Old 21-11-2009, 11:54 AM   #7 (permalink)
Super Moderator
asingh's Avatar
^^ ok will give it a try. Have a feeling it is something to do with the OC..! Am running it damn high.
asingh is offline
Old 21-11-2009, 12:00 PM   #8 (permalink)
Originally Posted by asigh View Post
Have a feeling it is something to do with the OC!
Doubted. Its a visible flaw for the chipset. Its not a big problem, its more like a nuisance.
Hardware BBQ
Old 21-11-2009, 02:13 PM   #9 (permalink)
Super Moderator
asingh's Avatar
You serious. Then what should I do..?? I am also doubting the CMOS battery..?
asingh is offline
Old 21-11-2009, 02:52 PM   #10 (permalink)
^^ About that being a nuisance rather a problem, yeah. You can try reseating the CMOS battery, its not a big deal and no harm trying.
Hardware BBQ
Recommend a motherboard with E7500 Processor? codeash CPU / Motherboards 7 14-10-2009 03:12 PM
Motherboard (startup Intel logo) problem daemon Hardware Q&A 8 22-11-2006 11:46 AM
upgrade for intel845gl motherboard rajat263 Hardware Q&A 2 26-10-2006 05:52 PM
