Old 19-11-2009, 08:09 PM   #1 (permalink)
Err.. what?
BSOD's Avatar
Default Need New PSU and Cabinet
Recently my PSU failed due to some problem with the power supply in my area. It was a VIP 500W(sigh).
Also, I was looking for better cabinet ( from someone like Cooler Master, not something crappy like Zebronics's which I already own). I have set aside a sun of 5k for the two.
Advice?
Ps. Posting from my cell
Asus P5N-E SLI, XFX 7600GT, Intel E6420, Transcend 1GB DDR2-667, Asus VW192T, WD 250GB SATA + Seagate 1TB 7200.12
BSOD is offline
Old 19-11-2009, 09:31 PM   #2 (permalink)
I am the night! I am....
vickybat's Avatar
Smile Re: Need New PSU and Cabinet
hi mate
you can go with gigabyte superb 460 @ 2.2k for psu and coolermaster cm 335 @ 2.3k for cabinet
vickybat is offline
Old 19-11-2009, 09:56 PM   #3 (permalink)
Cool G5's Avatar
Default Re: Need New PSU and Cabinet
Corsair VX 450 PSU & CoolerMaster 334/335 cabinet.
Both should come within your budget. If the Corsair is pricey you can get from equivalent PSU from Tagan.
Cool G5 is offline
Old 19-11-2009, 11:17 PM   #4 (permalink)
vickybat's Avatar
@ BSOD
If you can up your budget upto 6.4k then you can opt for what Cool G5 has suggested.
The vx450 is indeed a great psu & i even own one!
Tagan 500 u37 is also good and considerable if you cannot up your budget.
vickybat is offline
Old 20-11-2009, 02:14 AM   #5 (permalink)
Crowman
Krow's Avatar
CM Elite 334/5 @ 2.1k
Gigabyte 460W Superb @ 2.2k
Guys, have a look at his rig, this should be more than enough. If BSOD wishes to upgrade the whole rig later, ten its best if he gets a minimum of Cooler Master REAL Power Pro 460W @ 3.5k. Remember this is not CM Extreme but its CM Real. The Extreme series is bad. Its better to get CM Real Power Pro 460W as it will be able to power any system with upto HD5850 as a graphics card.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 20-11-2009, 07:44 AM   #6 (permalink)
Err.. what?
BSOD's Avatar
Thanks guys. I forgot to add the 1tb hdd I bought recently in the signature. That shouldn't affect too much though. Also, the only probable upgrade in the future that will draw power will be a low end gfx card, as I'm not much of a gamer. So, the superb should be enough. I wanted ask about its availability in Bangalore?
Thanks again.
BSOD is offline
Old 20-11-2009, 08:19 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@BSOD, since you already have a cabinet, my suggestion for you is to get a PSU and UPS. If you are facing power surges in your locality that damages PSU, even a 20k rupee Titanium certified PSU can't escape from that.
If you already have an UPS and still your PSU failed, that still means that you need to get a better UPS or get existing one repaired to stop power spikes/surges.
desiibond is offline
Old 20-11-2009, 08:24 AM   #8 (permalink)
Super Moderator
asingh's Avatar
Yea you would need a good UPS. Spikes/surges can damage the best of PSU. The CM PSU which Krow recommended is nice. It will do well for you. The 1 TB HDD will make a difference of 10-12W to total requirement, so you are still good to go.
asingh is offline
Old 20-11-2009, 08:35 AM   #9 (permalink)
Err.. what?
BSOD's Avatar
I already have an UPS. The PSU was showing signs of failure, such as its fan had stopped. So, it may not be directly related to the power problem. I must add that the UPS is for the complete house... that means even if I get a UPS for the computer it will be useless. Thanks again.
BSOD is offline
Old 20-11-2009, 08:53 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
hmm. No problems then. so, look for VX450W+Zebronics bijli option. 4k+1.3k I think.
And yes, Zebronics Bijli is a decent cabinet to use. just that it doesn't have screwless installation.
IMO, It's better to get solid PSU with decent cabinet than to get decent PSU with solid cabinet.
Old 20-11-2009, 10:44 AM   #11 (permalink)
Cool G5's Avatar
Zebronics Bijli is the best cabinet in the 1k range IMO.
Cool G5 is offline
Old 20-11-2009, 11:45 AM   #12 (permalink)
Crowman
Krow's Avatar
To keep things in budget, the CM Real Power Pro 460W @ 3.5k is a great buy, if OP can up his budget, then VX450W for 4k for sure.
Krow is offline
Old 20-11-2009, 01:22 PM   #13 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Advice?
CM Elite 310 @ 2k
Gigabyte Superb 460W @ 2.2k
Total = 4.2k
Save the bucks. Unless u wanna upgrade later on to a good GPU or the whole system.
Corsair VX450W @ 4.1k
or
Glacial Power 650W @ 4.7k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 20-11-2009, 10:02 PM   #14 (permalink)
Err.. what?
BSOD's Avatar
Okay. I'm thinking of going with Elite 335 and Real Power 460W. Both together should set me back about 6k.
Now, I am also planning to buy kingston value 2x2gb and a cpu cooler(the old stock is not performing as well as it should) and thermal paste for the same. A cheap but, good one will do.
Thanks.
BSOD is offline
Old 21-11-2009, 12:17 PM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^y r u spending soo much on the rig???? It's gotten old already......Better get:
Corsair VX450W @ 4.1k than a CM Real Power...
About me:
Please suggest a cabinet w/o PSU for around 2k bippukt Hardware Q&A 13 21-08-2009 11:55 AM
suggetion for new mobo proccy hdd and cabinet with good PSU bhoolkumehul Hardware Q&A 4 27-03-2007 05:28 AM
Prices Wanted for PSU and Cabinet !! rockthegod Hardware Q&A 21 25-03-2007 02:22 PM
Two SMPS or PSU in One Cabinet tiblu Hardware Q&A 11 10-03-2006 01:27 AM
- by bhaskar
