Old 19-11-2009, 03:26 PM   #1 (permalink)
Ashis's Avatar
Unhappy Installing 1TB HDD!
I have an Old HCL Beanstalk Desktop!
MOBO: MSI
ChipSet: 845G
Will I be able to install & run a 1TB Internal HardDisk?
Ashis is offline
Old 20-11-2009, 01:40 AM   #2 (permalink)
Default Re: Installing 1TB HDD!
Hi,
I assume you do not have any SATA port under this motherboard, hence I doubt that there wont any chance of direct installation..
However you can always use an USB connector to connect any size of hard-drive..
Hunky is offline
Old 20-11-2009, 02:11 AM   #3 (permalink)
Crowman
Krow's Avatar
Give exact model number of the motherboard. Best check on MSI official website and find out whether it has a SATA 2.0 port. I assume it must have this. How old is your computer? If it does have a SATA port, then your HDD will work like a charm. 1TB Seagate 7200.12 is for 4k and WD Green 1TB is for 4.1k.
If not, then go for an external HDD like the WD My Book Essential Edition 1TB @ 5.1k, which uses a USB interface, but will need an external power source, i.e., a spare plug-point.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 22-11-2009, 08:22 AM   #4 (permalink)
harishgayatri's Avatar
You can.
But first check for SATA ports.
If you dont have SATA ports then check whether you have an empty PCI slot.
if yes then get a PCI SATA card and insert it and then connect it to your 1TB HDD.
That should solve your problem
harishgayatri is offline
Installing OS on a External HDD ~User Name~ Software Q&A 4 14-03-2008 11:56 AM
Portable HDD + Casing Config Help knoughtyd PC Components / Configurations 6 14-11-2007 04:10 PM
migrating to a new HDD. manmay QnA (read only) 9 23-08-2007 11:07 AM
Installing OS in a usb drive (ext HDD or pendrive) and booting from it. aditya.shevade Software Q&A 8 24-07-2006 05:00 PM
Installing Linspire on HDD Aijaz Akhtar Open Source 4 16-06-2005 06:50 AM
- by bhaskar
