Old 17-11-2009, 06:26 PM   #1 (permalink)
ashish1224's Avatar
Default CPU, MoBo & RAM within 6.5k
Well friends I am upgrading an old PC and I am pretty tight on the budget
Will need the thee within Rs 6500.
Processor:
I have no preference or prejudices for either AMD or INTEL. Anything which is better bang for bucks will do.
Motherboard:
Must have decent inbuilt graphics(as far as possible). Of course I have no plans for a GPU in the near future.
RAM:
Will buy DDR2 with the remaining money.
Budget is pretty low... give your best bet. And THANKS A LOT in advance.
ashish1224 is offline
Old 17-11-2009, 08:03 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: CPU, MoBo & RAM within 6.5k
AMD Athlon II X2 240: 3k or Sempron for 2k
Gigabyte GA-MA74GM-S2: 3k
Transcend 1GB DDR2 800MHz : 1k-1.2k
desiibond is offline
Old 21-11-2009, 12:34 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Athlon II X2 240 @ 2.8k
Biostar A785G @ 3.4k
Total = 6.2k
RAM 2GB @ 1.8k or so...or buy second hand
Total 8k
Sorry mate, but this is the cheapest, and BEST option too...
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 21-11-2009, 01:14 PM   #4 (permalink)
Off Hook!
v.Na5h's Avatar
Post Re: CPU, MoBo & RAM within 6.5k
Finally i have decided to replace my old PC after my exams......
Budget around 40k
Iam planning to buy it in Jan 2010 end
And iam not going to upgrade it for at least 5 yrs
So should i buy a dual core or a quad core processor
i am thinking about either
AMD Phenom II X4 or
AMD Phenom II X2
Will any of the AMD quad core processors available around 6-7k
Core i3 530 @ 2.93Ghz | Kingston 4GB (2GBx2) DDR3 1333MHz | Gigabyte GA-H55M-S2H | Acer S231HL 23" LED Monitor | Nvidia GTS 450 | Seagate Barracuda 1TB | FSP Saga II 350w | CM Elite 310 | | Philips HTS 5.1 SP100
| Zotac GTS 450 |X360 Gamepad |
Dell XCD35 powered by CM9, Soundmagic PL11 earphones, Samsung class 6 16GB
TV Shows / Movies .....I have watched....
v.Na5h is offline
Old 21-11-2009, 02:18 PM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
AMD Athlon II X4 620 quad core processor is already available for 5.5k
anyways, as you are going to make the purchase in Jan, we will discuss when you are ready to buy
Old 21-11-2009, 08:41 PM   #6 (permalink)
I am the night! I am....
vickybat's Avatar
Smile Re: CPU, MoBo & RAM within 6.5k
Budget around 40k
AMD Phenom II X4 or
AMD Phenom II X2
If you wont be upgrading for next five years i suggest you go the intel way and get the core i5 750 along with a good p55 platform.Its much more future proof than amd right now.At 40k for total budget you can easily investin the i5.
vickybat is offline
Old 21-11-2009, 09:52 PM   #7 (permalink)
Super Moderator
asingh's Avatar
Yea, the i5+P55 offers much more future proof status then the AMD X4.
You could go with..
Core i5-750 2.66Ghz - 10150
Gigabyte GA-P55M-UD2 - 7350 (corrected as below)
GPU : Powercolor HD4890 1GB DDR5 - 11890
2 X 2GB DDR3 1333 - Kingston 4 GB - 4600 (for dual-channel)
HDD : Seagate Barracuda 7200.12 - 500GB SATA - 2371
PSU : Tagan BZ500(modular) - 4463
Chassis : Coolermaster Elite 335 - 2132
Total: 42956
You can play around with the GPU and Chassis and HDD to tweak prices.
asingh is offline
Old 22-11-2009, 12:51 PM   #8 (permalink)
vickybat's Avatar
@ asigh
hi buddy
The asus p7p55d-evo is 7.3k? Is it true?
I thought its well over 12k.
Asus is yet to launch a p55 board i.e an le model which should be around 6-7k.
Posted again:
@ asigh
hi buddy
vickybat is offline
Old 22-11-2009, 02:20 PM   #9 (permalink)
Super Moderator
asingh's Avatar
^^ You are right. That is the X58 model I put...it should be 13838
asingh is offline
Old 23-11-2009, 03:11 PM   #10 (permalink)
Off Hook!
v.Na5h's Avatar
yeah iam convinced that i5 is a better option
i have heard some news that a cheaper version of i5 clarkdale with the integrated graphic core will appear in the beginning of 2010.
should i wait for that....
or buy the i5-750
can u estimate wat its price may be in feb10
v.Na5h is offline
Old 23-11-2009, 09:51 PM   #11 (permalink)
+1 for desiibond’s suggestion
otpsurvive is offline
A newbie's guide to Overclocking a Athlon XP CPU TheMask Tutorials 180 10-06-2008 10:58 AM
Best Mobo for Dual core 2.8 with 1GB Ram u scamper Hardware Q&A 5 05-03-2007 05:40 PM
Fantasies of Overclocking - OC guide quad master Overclocking 14 15-12-2005 08:00 PM
The Ultimate B.B.D.O.T.S.M.M. Software Guide quad master Software Q&A 2 09-12-2005 07:51 PM
Can I add RAM of other manufacturer to my mobo Ram_Kumar Hardware Q&A 4 08-11-2005 07:02 AM
- by bhaskar
