Old 17-11-2009, 02:22 PM   #1 (permalink)
Default How to divide bandwidth equally between 2 comps?
Hi,
i have a "pronet pn-54wrt" router,
i am sharing my tataindicom comnnection with my roommate,
if 1 pc is downloading a heavyfile, then the second pc get very little bandwidth.
is there any way in which both pc's can get equal share of bandwidth?
Absolute0 is offline
Old 20-11-2009, 01:44 AM   #2 (permalink)
Default Re: How to divide bandwidth equally between 2 comps?
Hello,
I can be wrong, but as far as I know, you cant enforce such rule directly from the given router..
You need to have a Server installed, which shares the connection between 2 static IP. The sharing server would need to have policy to allow only a certain amount of bandwidth consumption..
Hence sorry again, there is no plug n play solution !!!
thanks..
Hunky is offline
Old 20-11-2009, 01:47 AM   #3 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
My router does that... splits the bandwidth equally, or unequally using some rules. Check if your router does that too. You can also use Free Download Manager on the downloading PC, and then restrict the bandwidth using the download manager. I know of FDM, but I am sure there are other download managers that allow you to restrict bandwidth.
IDDQD IDKFA
Anorion is offline
Post Your Benchmark Results Here topgear Hardware Q&A 71 05-10-2008 11:57 AM
Increase bandwidth speeds( finally smthin that works) blademast3r Tutorials 12 16-03-2007 09:08 PM
Increase your Bandwidth by 20% rakeshishere Tutorials 1 04-07-2006 12:36 PM
Sony Announces PlayStation 3 Pricing Xtra Technology News 14 14-05-2006 06:53 PM
Make ur Internet n Bandwidth Rapid - Rapid Speeds 100% works Quiz_Master Tutorials 4 12-02-2006 10:50 PM
- by bhaskar
