Old 16-11-2009, 04:39 PM   #1 (permalink)
sriharsha_madineni's Avatar
Question Is aftermarket thermal paste really necessary??
I have a small doubt regarding CPU thermal paste,Recently my motherboard was replaced under warranty and during that gap my proccy and fan were kept aside in a box.Now my doubt is,is that gonna affect thermal paste in any way and do u really need to apply aftermarket thermal paste again???
My Processor thermal margin is showing 44-45C right now and is in green in intel desktop utilities normally.But occasionally a warning pops out that my proccy thermal margin went below 13C.My guess is that would be a false report since it goes into 40-45 range within no time.
but i want to be sure that I'm not risking anything with my proccy and Do I need to apply thermal paste again.
Alos wanted to what exactly are the benefits of using aftermarket thermal paste apart from cpu running cooler.
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now
Old 16-11-2009, 04:44 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Is aftermarket thermal paste really necessary??
yes. thermal paste need to be applied if the heatsink is detached and it's a must!
desiibond is offline
Old 16-11-2009, 04:51 PM   #3 (permalink)
Super Moderator
asingh's Avatar
+1.
You better do that..the first thing, before even booting your computer again.
Also use RealTEMP along with Prime95 and get a differential gradient chart, for your CPU temperatures. PLEASE do this after putting new TIM.
asingh is offline
Old 16-11-2009, 04:52 PM   #4 (permalink)
Anna suggest some along with their price,also availability at S.P. Road
Is anything alarming in that screen shots??
Is stock C2D heatsink enough for normal use??No overclocking
@asigh
are u running @4ghz on stock cooler,heard E8400 can be overclocked to 4Ghz on stock cooler
Old 16-11-2009, 05:03 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Get Coolermaster Fusion for RS 350-400. Has no settle in period.
Am running it on a Hyper 212 HSF with the above TIM.
Cannot make out your screen shots. Post a screen shot of the diagnostic I suggested. Will let you know.
Stock HSF is good enough for NON-OC. But the TIM should still be there, to insure integral mating of the HSF and CPU header. Doubt you can push the E8400 to 4 Ghz on stock. Too much vCore will go in. Immense heat. Its risky.
asingh is offline
Old 16-11-2009, 05:23 PM   #6 (permalink)
@asigh
downloaded both,now which tests should I run??
Old 16-11-2009, 05:23 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@asigh
no need for aftermarket cooler if you are not overclocking and the stock cooler should do well for small overclock.
follow asigh's suggestion for thermal paste.
some shops there will try to give you 50 rupee local made thermal pastes and say that branded ones are unavailable. don't fall for that.
Old 16-11-2009, 05:25 PM   #8 (permalink)
Cool G5's Avatar
You can even try searching to Tuniq TX2 which costs Rs.200.
Cool G5 is offline
Old 16-11-2009, 05:32 PM   #9 (permalink)
oops ran sensor test and suddenly proccy temp rose to 100C and IDU started showing pop ups that proccy margin went below 13 and was continuously blinking in red.
Oh no I should have read your post clearly,I did this on stock TIM
Old 16-11-2009, 05:32 PM   #10 (permalink)
Super Moderator
asingh's Avatar
@asigh
1. Launch RealTEMP.
2. Via Setting set TjMax to 90
3. Click on sensor test.
4. Show the Application the Prime95 EXE. (It will ask for it).
5. Choose 2 worker threads.
6. Let it run till the end. You will get a temperature log on the RealTEMP front end.
7. Post a screen shot of that.
8. Keep Task Manager Open.
Keep a close watch. If you get an over heat signal (like you were before), immediately make a screen shot of Prime95 (I want to see the threshold), and kill RealTEMP and Prime95 via tax manager.
Please do not run the above, and walk away. You will need to monitor.
Posted again:
Guess you typed this, while I was typing the above.
See if you can make a screen shot.
asingh is offline
Old 16-11-2009, 05:34 PM   #11 (permalink)
Shall I run it now or wait till I get new thermal Paste
Old 16-11-2009, 05:40 PM   #12 (permalink)
Super Moderator
asingh's Avatar
Actually do not run it. The way you described, your temperature shot up too fast. Keep this post as a bookmark, and do what I suggested once the TIM is installed and the HSF re mounted.
Clean the CPU and HSF contact surfaces lightly with Isopropyl Alcohol. Let it dry, then mount. Spread the TIM thinly over the CPU header.
Post back once all this is done, we can then take it forward. Till you do not have the new TIM placed, try not to stress the system (gaming, encoding).
Best of luck...!
asingh is offline
Old 16-11-2009, 05:40 PM   #13 (permalink)
Cool G5's Avatar
Post Re: Is aftermarket thermal paste really necessary??
Get the thermal paste first.
Cool G5 is offline
Old 16-11-2009, 05:48 PM   #14 (permalink)
Well yes temp is shooting up to 100 within secs of starting the test,is that alarming or normal??
Old 16-11-2009, 05:51 PM   #15 (permalink)
Super Moderator
asingh's Avatar
Yes this is really bad.
1. Your HSF is 100% not seated correctly.
2. TIM needs to be applied.
You seriously made this screen shot a few seconds after starting the Sensor test.
What have you set TjMax too..?
asingh is offline
Old 16-11-2009, 05:52 PM   #16 (permalink)
Learn & Earn
puneetgarg's Avatar
wow thats really hot temp...u must surely do something about this
яєѕρє¢т ιѕ єνєяутнιηg
puneetgarg is offline
Old 16-11-2009, 06:01 PM   #17 (permalink)
Thank god at least I realized somethings wrong with my proccy temps early.
I mean not during the tests,but after fixing it back just a few days ago,If this is the case then I guess i've been running like this for a year now!!!!
coz my proccy and heat sink were removed even before this,i.e last time when my mobo went kaput some 1yr ago.
Is that a question or expression
Old 16-11-2009, 06:03 PM   #18 (permalink)
Super Moderator
asingh's Avatar
Question...
Also I asked..about TjMax. What is that set too..?
asingh is offline
Old 16-11-2009, 06:06 PM   #19 (permalink)
First time I ran it on defaults and temps were 100 within just a sec or two.
then I changed max tj to 90 and ran test again,the screen shot was after second attempt,again temps were max within seconds
Old 16-11-2009, 06:10 PM   #20 (permalink)
Super Moderator
asingh's Avatar
ok..thanks..
Just do not stress the system. Be very gentle with it. Do what we all suggested. And run the test.
asingh is offline
Old 16-11-2009, 06:14 PM   #21 (permalink)
ok..thanks..
ohh it would take atleast a week for me to get the thermal paste and I'm upgrading my PSU too just in case.
Old 17-11-2009, 12:36 PM   #22 (permalink)
@asigh
This is what I was talking about E8400 @4.0Ghz.I'm not into overclocking BTW my concern is to run proccy at cool temps .
Was reading this yesterday about c2d and i7 temp calibrations,nice detailed info,got to know a lot from this.
So what is the ideal temp range for my proccy under normal loads and Full loads???
check out the temp at diff loads in that first link,At present my proccy is averaging 50C at just 4-5% load.
Also my gfx card is showing 54C at idle,is it ok??
Old 17-11-2009, 01:14 PM   #23 (permalink)
Super Moderator
asingh's Avatar
^^ Ideally for your processor - at stock.
Idle : 33c-35C
Full Load : Should not go above 55C
asingh is offline
Old 17-11-2009, 02:53 PM   #24 (permalink)
@asigh
The culprit was loose heatsink which was not seated properly.After fixing it,I performed those tests again with Tj max set to 90,thankfully this time the temp changes were not sudden.temps were increasing slowly as loads increased.Anyways all these were done with cabinet side panel removed.
Will again test it with side panel closed tomorrow and let you know the results and yeah thermal paste looks like it's dried out,hmm gotta replace it with new one.
Also the stock cooler has this problem of not seating properly,are there any sub 1K aftermarket coolers or Should I stick with the stock one.
Here are the results
Old 17-11-2009, 02:57 PM   #25 (permalink)
Super Moderator
asingh's Avatar
^^ These temperatures are good. With good TIM, they should come down 4-5 degrees more.
Yes, stock HSF is bad. It at times does not seat properly, no matter how hard you press the push pins. Though if you are not OC'ing you can live with these temperatures.
You plan to OC...?...We can suggest better HSFs. Keep a budget of at least 2.4k.
asingh is offline
Old 17-11-2009, 03:01 PM   #26 (permalink)
ahhh relieved man
no plans to OC as of now and that too i'm on Intel Original board so no OC for me I guess.
BTW is 55C ok for my XFX 9600GT on idle??
So may I skip using newThermal paste as of now coz iIcan spend that amount on my other upgrades now.
hehehe found this old thread below the page in similar threads
OT @desiibond
Anna is this you by any chance??Found this in the thread above. Profile name sounded familiar
Old 17-11-2009, 03:38 PM   #27 (permalink)
Bond, Desi Bond!
desiibond's Avatar
oh yes. that was mine. i used my company's userid. after sometime, created new account
Old 17-11-2009, 03:40 PM   #28 (permalink)
couldn't wait untill tomorrow,So ran blend torture test with Tj max set to 90,cabinet closed and processor Fan response set to aggressive in BIOS.
Old 17-11-2009, 04:43 PM   #29 (permalink)
Super Moderator
asingh's Avatar
^^ Still a shade on the higher side, but will not harm.
Post good TIM, you should see nice change. I still do not trust stock HSF.
asingh is offline
Old 19-11-2009, 09:13 AM   #30 (permalink)
@Asigh
what do you think about these temps,are they reduced
What is this sensor movement in the first row??
Thermal Paste substitute?? blackpearl Reviews 27 14-10-2008 11:33 AM
lithium based thermal paste chesss Hardware Q&A 13 28-12-2007 10:17 PM
Please List Basic C2D / Dual Core Overclocking Tips Choto Cheeta Overclocking 101 18-12-2007 09:31 PM
is Thermal paste really needed? anilmail17 QnA (read only) 3 30-05-2007 03:29 PM
No Thermal Paste !! adorablesrini Hardware Q&A 9 24-02-2007 01:16 AM
- by bhaskar
