Old 15-11-2009, 07:23 AM   #1 (permalink)
Default Display Not Coming Always
Hi guys,
I have a problem with my C2D system. The display refuses to come at times. Noe its frequency has increased. Also at times the display stops by displaying the BIOS screen. But even when i try to enter it, it does not enter. Its hung & i cant even power it down by the cabinet switch.
Also once i switched by PC for about 15mins in Ubuntu & then opened the cabinet to find that my graphic card was really hot compared to the motherboard heat sink. I use an XFX Geforce 8500GT 512MB graphic card. So i removed & tried with the VGA slot on the motherboard. But still there are problems with the display. I even tried operating my PC on just 1GB Ram stick only. Still no use.
My motherboard is an Intel G31PR based on the G31 chipset.
Somebody please help me....
nithishr is offline
Old 15-11-2009, 02:53 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Display Not Coming Always
Seems like a PSU problem. Which one you have. Though your system should not need that much power, the 8500GT is not power hungry.
asingh is offline
Old 15-11-2009, 07:06 PM   #3 (permalink)
My PSU is a Mercury 400W one that came with my cabinet.
nithishr is offline
Old 15-11-2009, 07:20 PM   #4 (permalink)
Super Moderator
asingh's Avatar
^^ Try another PSU.
Also I had the XFX 8500GT. It comes with a heat sink and no fan. Even mine used to get damn hot, then I mounted an OEM HSF. See if you can do that.
asingh is offline
Old 17-11-2009, 03:31 PM   #5 (permalink)
Let me check the PSU
nithishr is offline
Old 22-11-2009, 12:00 PM   #6 (permalink)
I got my XFX 8500GT graphic card replaced with an Asus 9400GT card. Now there seems to be no problems.. []
nithishr is offline
One Giant Command Line MetalheadGautham Open Source 23 24-05-2008 02:31 AM
Bet you never know this secrets ashish_patel Tutorials 34 14-01-2008 09:44 AM
We offer APPLE G4 POWERBOOK 1.5GHZ SUPERDRIVE WITH 15 INCH DISPLAY........$700 pdaworldltd Chit-Chat 2 02-09-2007 10:23 PM
Windows Sortcuts and commands rajat22 Tutorials 6 27-07-2007 04:17 PM
Opera 8.01- Final Released Curious Guest QnA (read only) 6 23-06-2005 11:18 PM
- by bhaskar
