Old 09-11-2009, 03:16 PM   #1 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default HD5770 - The real cause of bottleneck
ATi 5770 Bottleneck Investigation | AlienBabelTech
Okay everyone till now thinks AMD made a big mistake with the HD5770 series with a 128-bit interface, well I feel they shud have gone for 1200SPs and 256-bit both but leaving my thoughts alone....I came across this review which showed what is actually slowing down the HD5770 is the CORE over memory, this review speaks all!!!
Commentary
Well isn’t this interesting? The 5770 is primarily limited by its core overall, not by its memory!
Underclocking the core 20% results in a 11.20% performance loss overall, while doing the same to the memory results in a smaller 8.46% performance hit. This makes the 5770 a reasonably balanced card, with a small bias towards its core. This is unlike 8800 Ultra for example, which showed a massive reliance on its core across the board.
The results actually make sense given a 5770 is basically a 5870 chopped in half, and the 5870 was proven to be primarily limited by its core too. If you shrink the processing power and bandwidth in proportion to each other like the 5770 does (i.e. cutting both in half from the 5870), you’ll end up with very similar performance characteristics.
Also the performance hit increases when moving from 2xAA and 4xAA with the core (10.58% to 12.45%). We expect this to happen with the memory (and it does) but since the core is also affected, that tells us the ROPs are also bottlenecking the equation to some degree.
As for the individual games, we see Call of Duty 5, Wolfenstein, Call of Duty 4 and Fear 2 being massively more limited by the core than the memory, while the opposite applies solely to Bioshock. The rest of the games are affected reasonably equally by both clocks.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 09-11-2009, 04:48 PM   #2 (permalink)
Default Re: HD5770 - The real cause of bottleneck
Source?
Nice info. Well its meant for the mid range gaming segment anyways! Performance around the GTS250. There's a huge jump in between the 5770 and 5850. Something that ATI would soon fill up!
hell_storm2006 is offline
Old 09-11-2009, 08:12 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
u mean around HD4870, not GTS250....
Source?
AlienBabelTech (dotcom )
About me:
Old 10-11-2009, 10:10 AM   #4 (permalink)
No. I meant GTS250. Its just somewhere between GTS250 and GTX260.
http://www.techspot.com/review/209-ati-radeon-hd-5770/
http://www.guru3d.com/article/radeon...-review-test/1
http://www.bit-tech.net/hardware/gra...-5770-review/1
Sharing desktop remotely using real VNC Charan Tutorials 38 16-12-2009 05:36 PM
Real Player 11 beta for Windows Vista out now gxsaurav Technology News 6 14-06-2007 11:51 PM
Using multimedia keyboard to control Real Player bizzare_blue Software Q&A 8 18-11-2006 08:37 PM
How to uninstall real player in Nokia 3230??? sidewinder Mobiles and Tablets 3 24-03-2006 02:45 PM
Why isn't Real Audio Popular? ashok QnA (read only) 23 02-02-2005 07:17 PM
- by bhaskar
