Old 08-11-2009, 04:12 PM   #1 (permalink)
Default SMPS for Pentium III 800 mhz
So my 9 year old 235w mercury smps goes dead. The hardware dealer says putting a 450w smps might burn the motherboard and components. I could not find less than 450w smps anywhere.
So, i buy a second hand Kobian 235w, this worked for the first time. during the next boot started making loud noise...i remembered the seller had told me no return.
So i go and buy another used smps, this time a mercury 250w. Now, whenever i play a mp4 movie, it hangs after sometime. plays avi files fine.
I have a p3 cpu, 2hdd's, 1dvd-rw, 1cd-rw, geforce4mx, tvtuner, 56k modem, floppy drive
My original smps output was: 3.3v-10a, 5v-19a, 12v-8a
The 2nd hand mercury smps output: 3.3v-16a, 5v-25a, 12v-9a. Eventhough all the values are greater, it hangs.
So, my question is can i use the latest smps in the market for my system without any problem? and what's wrong with the 2nd hand mercury smps?
casual_gamer is online now
Old 08-11-2009, 09:43 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: SMPS for Pentium III 800 mhz
Get the corsair VX450
asingh is offline
Old 08-11-2009, 10:24 PM   #3 (permalink)
Crowman
Krow's Avatar
^That's overkill by a long shot. Get Gigabyte 460W Superb @ 2.2k. VX450W is for 4k and not needed for that config, but will be a bit more future proof.
Alternatively you may even look for a CM extreme power 400W SMPS which should be cheaper.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 08-11-2009, 10:28 PM   #4 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
I have a sahara 250W smps. See if can find one. It may not come without a cabinet though.
This doesn't sound like an smps problem. Have you tried multiple media players to play mp4 files? Try using some other media player like smplayer or vlcplayer to play mp4 files
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 08-11-2009, 11:27 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Okay revised...
Get a 450W SMPS..whichever..you are comfortable with.
asingh is offline
Old 09-11-2009, 06:32 AM   #6 (permalink)
there are signs suggesting an smps problem like monitor going blank for half a second, slowly everyday i am finding new signs.
For a new one, i am looking at cheaper options. How about, Odyssey 450w or Zebronics 450w? is it safe to use these with my 10 year old pc? The hardware vendor told me that a higher watt psu might burn the motherboard/components, is this true? Already i have wasted Rs.500 on second hand smps's due to this advice.
Old 09-11-2009, 07:58 AM   #7 (permalink)
Super Moderator
asingh's Avatar
The higher watt SMPS burning your system...that is a big pile of crap. He is totally BSing you. No ways, will it burn out a 'thing' on your system. It should be connected correct. That is about it.
Get a decent brand PSU.
asingh is offline
Old 09-11-2009, 11:41 AM   #8 (permalink)
Modern SMPS are all ATX power supplies, ain't it? And if i remember, PIII's use different type of PSU's! Although am not sure about this! Get a Zebby for this! It would work fine with PIII's. Why dont you get an upgrade done on that dinosour??? :-P:-P
hell_storm2006 is offline
Old 09-11-2009, 12:40 PM   #9 (permalink)
Super Moderator
asingh's Avatar
^^ It would have the ATX 20 PIN..I guess.
asingh is offline
Old 09-11-2009, 02:33 PM   #10 (permalink)
thanks for the replies.
yeah mine is ATX 20 pin.
I found an interesting discussion in http://www.sadikhov.com/forum/index....owtopic=118057 thread. I quote below
"There has been a change of spec on newer PSU's as newer motherboards now regulate the 12Volt supply to power the CPU where as older mobos for PIII's used the 5Volt supply to power the CPU. So what has hapened is that older PSU's could supply more current (AMPS) to the 5Volt rail, and because they don't need use it the newer PSU's have a lower spec output current on the 5Volt supply."
still a little confused.
ubuntu getting crash again and again contactpraven2001 Open Source 16 12-03-2008 05:09 PM
Nokia Processors - Hope its useful! solomon_paulraj Mobiles and Tablets 4 31-10-2007 02:57 PM
The Short List: the Best Gaming Videocards for the money drvarunmehta Hardware Q&A 10 18-10-2006 10:56 PM
- by bhaskar
