Originally Posted by hell_storm2006
Somebody please lock the other thread!
How old is your drive? Post a screen shot of your task manager with applications arranged in descending order of CPU usage!
it is 3 years old, when i try to burn cd's with nero ...the process starts fine...but after few seconds ...write error is displayed and cd is ejected( i have wasted 3 cd's in 2 days...)....i have saved the log and pasting log here.....data to be copied was on 2nd hard drive(maxtor...DMA is Off..(i have highlighted it) ..on for primary hard+dvd rw drive what it mean
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.0
Internal Version: 8, 1, 1, 0
Recorder: <SONY DVD RW DRU-810A> Version: 1.0a - HA 1 TA 0 - 8.1.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <SONY DVD RW DRU-810A >Version: 1.0a - HA 1 TA 0 - 8.1.1.0
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP0802N atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DRU-810A atapi Port 0 ID 1 DMA: On
DiskPeripheral : MAXTOR STM3250310AS 3.AA m5287 Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DRU-810A F: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1983MB (2030824kB)
Free physical memory: 1583MB (1620996kB)
Memory in use : 20 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.11.2009
CD Image
10:06:41 AM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:06:41 AM #2 Text 0 File Burncd.cpp, Line 3212
Power-Burn activated
10:06:41 AM #3 Text 0 File Burncd.cpp, Line 3530
Turn on Disc-At-Once, using CD-R/RW media
10:06:41 AM #4 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 286993 ( 63:48.43)
10:06:41 AM #5 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
10:06:41 AM #6 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: SONY DVD RW DRU-810A;
CDR code: 00 97 24 16; OSJ entry from: SONY Corporation
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 18 10 (LI 97:24.16), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
10:06:41 AM #7 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
10:06:41 AM #8 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 286994 (286994) = #286994/63:46.44
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 286994 blocks [F: SONY DVD RW DRU-810A]
10:06:41 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [F: SONY DVD RW DRU-810A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 588070912, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 286994 | 286994 | 0x00
286994 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:06:41 AM #10 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
10:06:41 AM #11 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
10:06:41 AM #12 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
10:06:41 AM #13 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
10:06:41 AM #14 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
10:06:41 AM #15 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 32x (4,800 KB/s)
10:06:41 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2735
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
10:06:41 AM #17 Text 0 File MMC.cpp, Line 17745
StartDAO : CD-Text - Off
10:06:41 AM #18 Text 0 File MMC.cpp, Line 22430
Set BUFE: Power-Burn -> ON
10:06:41 AM #19 Text 0 File MMC.cpp, Line 17973
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 3f 30 2c
10:06:41 AM #20 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
10:08:26 AM #21 SPTI -1135 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 02 23 00 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 12 00 00 00 00 0C
Buffer x091587c0: Len x10000
0xB2 98 E4 9A 52 4E 72 14 0A C0 56 D4 2A D4 81 E3
0x3B 02 89 E3 02 6B 4C 52 1D 2B DA E5 86 0C EA C1
0xF3 7F 4F 5D 4B 03 27 58 73 AC 3E 4D 78 B9 99 C7
10:08:26 AM #22 CDR -1135 File Writer.cpp, Line 306
Write error
10:08:26 AM #23 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 32x (4,800 KB/s)
10:08:26 AM #24 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:08:31 AM #25 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
10:08:31 AM #26 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
