Old 06-11-2009, 10:32 AM   #1 (permalink)
Angry Hard disc not detected
Hai Friends
I am using Compaq Presario SR1512IL Desktop PC the following is the specification
http://h10025.www1.hp.com/ewfrf/wc/d...reg_R1002_INEN
In my PC they gave 40GB harddisc with that i have added 160GB sata harddisc i works fine for nearly 1 year after that i started creating problem i have tested my 160GB hard disc with seagate hard disc checking software it gets failed in some tests so i have changed my hard disc now i got the new one
Here is the problem i am using XP i have installed XP in 40GB hard disc some time this new 160GB sata hard disc was not detected in XP i have checked in bios its get detected and also if i run the smart test form bios some times its getting failed some times its working fine.. when the smart test become pass XP is able to detect that hard disc but after some times again that hard disc get vanish inside XP
Please help me.. I have to know weather it is hard disc problem or my system problem i have changed my hard disc before 5months only
Waiting for your valuable replies
surenther.ss is offline
Old 06-11-2009, 11:10 AM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: Hard disc not detected
try to change Power Cable of HDD and/or SATA Cable of HDD
the other thing can be - ur PC looks too old so may be ur motherboard is feeling tired and needs to get retired
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 06-11-2009, 09:27 PM   #3 (permalink)
CA50's Avatar
yeh try the power and sata cable, ur power unit might be the culprit, for providing low power. check that too
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 10-11-2009, 08:03 PM   #4 (permalink)
cosmos's Avatar
Power prblm or dusty old motherboard or loose HDD cable....Chk all of these...One should solve ur prblm....
Cheers,
Anup
cosmos is offline
Brand new hard disk not being detected. jawash QnA (read only) 2 04-06-2008 04:53 AM
Hard Disk is not detected in Acronis True Image CadCrazy Software Q&A 6 02-09-2007 10:40 AM
My hard disc is not detected avis_gan Hardware Q&A 10 01-06-2006 11:12 PM
suggest external hard disc upto 100GB .:;AddICtEd;:. Hardware Q&A 11 11-01-2006 02:17 PM
ULTIMATE HARD DISK SETTINGS - brain racking question sincereheart QnA (read only) 6 16-10-2005 12:53 PM
- by bhaskar
