Old 04-11-2009, 11:59 PM   #1 (permalink)
Default SATA HDD with a PATA HDD
I have a 4 year old branded computer from HCL with 80 GB hard disk. Is there any way I can find out if it's SATA or PATA, by software or any other means? If it is a PATA hard disk,can I team it up with a new SATA one or will there be compatibility issues?
swaroop123 is offline
Old 05-11-2009, 12:13 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: SATA HDD with a PATA HDD
Open the cabinet
And see wheather it's connected using IDE cable if yes then its PATA
If not then its SATA. SATA drives r connected using SATA cables to SATA ports(usually red coloured cables)
Otherwise go 2 ur BIOS........u can know wheather u r using SATA/PATA HDD 4m thr.....
U can also use TuneUp Utilities(Machine information) to know this
If u r using PATA HDD u can go for SATA HDD.......thr will b no campatibility issue with tat........
BTW 4 years old machine denotes its PATA HDD probably......!!
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
Last edited by krishnandu.sarkar; 05-11-2009 at 12:16 AM. Reason: Automerged Doublepost
krishnandu.sarkar is online now
Old 05-11-2009, 12:19 AM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
Yes, most probably it will have PATA HD only.
Blogging at:
Technostarry
saqib_khan is offline
Old 05-11-2009, 12:38 AM   #4 (permalink)
Cool G5's Avatar
It will most be PATA or IDE HDD.
Cool G5 is offline
Old 05-11-2009, 01:58 PM   #5 (permalink)
Thanks friends, I just find out about my hard disk using Tune Up Utilities and surprisingly,it is a SATA hard disk.The model number is WDC WD800BD-22LRA0. I will be buying a 250 GB SATA this weekend, preferably from WD. Can I format or partition the hard disk myself? Please guide me about how to do it.
By the way,is 7800 gtx a better card in terms of game performance than 9600 gt, without taking into account the DirectX 9 or 10 factor?
Old 05-11-2009, 03:32 PM   #6 (permalink)
Cool G5's Avatar
Yes you can format it yourself. Right click on My Computer>Manage>Disk Management> Right Click & Start making partitions as per your requirements.
Or you can boot via G-Parted CD & do the partition.
Cool G5 is offline
Old 05-11-2009, 07:16 PM   #7 (permalink)
I M A *STAR*
saqib_khan's Avatar
@swaroop123
Yes, 9600GT is ofcourse a better card, compared to 7800.
Blogging at:
Technostarry
Help needed. Things needed to connect SATA HDD to... prashantmaxsteel Hardware Q&A 3 21-11-2007 12:26 PM
Portable HDD + Casing Config Help knoughtyd PC Components / Configurations 6 14-11-2007 04:10 PM
New 250GB SATA 2 HDD nishantv2003 QnA (read only) 11 27-09-2007 11:00 PM
Help Required regarding sata HDD silkyboy Hardware Q&A 2 17-05-2007 11:02 AM
Guys Suggest me ....SATA or PATA.. shyamno Hardware Q&A 6 16-04-2007 10:13 AM
- by bhaskar
