04-11-2009, 09:42 PM
Be CoOl rAp RuLeZ !!!
Suggest a rig for 20-25k
Ok my budget is between 25k
I asked desibond for a config he suggested me this for 18k
Core i5 750: 10.5k
Gigabyte P55 board: 7k (you need external GPU)
Corsair DDR3 1333MHz RAM 2GB : 3k-3.5k
or
Phenom II X4 955 BE: 9k-10k
MSI 785G based board: 4.5k-5k
Transcend 2x2Gb DDR3 1333MHz : 5k-5.5k
My requirements are
Running some resource eating softwares
Hardcore internet usage
casual gaming lol
Please rebuild my CPU.. I guess I don't need a GPU as I am not much interested in gaming
windows 7 should run perfectly but..
that's it....
Thanks everyone ..
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
04-11-2009, 10:45 PM
Super Moderator
Re: Suggest a rig for 20-25k
They Phenom II D.Bond recommended is good..!
05-11-2009, 02:24 PM
suggest a monitor even withing 6k
05-11-2009, 03:33 PM
Within 6K you can get Acer LCD which I don't recommend. Get atleast Samsung 2033SW.
05-11-2009, 03:47 PM
Super Moderator
I think the DELL 19" should be manageable within 6K too. 1400 x 900
05-11-2009, 07:03 PM
BSD init pwns System V
If you don't wanna game then there is no point of getting those ultra high end Core i5 or Phenom II X4... instead settle for Phenom II 720 BE or Athlon II 620.. those are far more cheap and will be sufficient for your usage..
Phenom II X3 720 BE - 7.5k
Athlon II X4 620 - 6k ( I guess)..
Biostar TA 790 GX BE Mobo - under 5k...
4 GB RAM - 2500
Gigabyte 460 W PSU - 2000
WD 500 GB HDD - 2700
Cabinet - 1-2k
and go for that Samsung monitor...
06-11-2009, 12:06 AM
Crowman
Dell E1909W is for 6.5k. Samsung 2033 SW @ 6.8k is a minimum one should buy.
MSI 785GM-E51 is for 4.6k with DDR3 support. Get Phenom II X4 945 @ 8.5k and save 1k on CPU with losing a clock of 0.2GHz. 955BE is 3.2 and 945 is 3GHz.
DDR2 RAM is like 2k+ for 2GB so get DDR3 minimum. I recommend the MSI 785GM-E65 @ 5.6k along with DDR3 support.
06-11-2009, 12:09 AM
I am the night! I am....
hi guys
For the lcd within 6 -7k go for the awesome aoc f19.
Its great for the price and received the gold buy award in digit review.
I guess you should stick with the core i5 750 proccy as its future proof and beats all phenom 2's.
For the board get the gigabyte p55 ud2 and if in a tight budget the intel dp55wb shall do fine at 6.3k.
23-11-2009, 09:22 PM
The Intel offerings presently are too confusing and are demanding a premium. I will recommend sticking with AMD. Simple two sockets AM2+ and AM3 and AM3 backward compatible. Support for both DDR2 & 3. It gives you the independence of choice. So, it is the best. And the AMD config that you’ve mentioned looks good. Go for it. As for the monitor, there’s the BenQ T2200HD which is retailing currently for around 8.5k. At that price, it is a steal and you’ll never regret getting a big monitor any day. Bigger the better.
25-11-2009, 10:54 AM
Hey guys I changed my mind a little bit...... I now need a gaming rig for that budget can u all please alter your suggestions a lil bit plZ
26-11-2009, 12:44 PM
laborare est orare
For gaming rig, at least 30-35k will be required.
Here goes your suggestion
1. Processor: Athlon II X4 620 @ 5k
2. Mobo: MSI 785GM-E51(AM3, DDR3, 4 ram slots)@4.5k
3. Ram: Kingston 2 GD 1333 MHz DDR3 @ 2.4k
4. HDD: Seagate 7200 RPM 500 GB SATA 2.4k
5. Cabinet: Zebronics Bijli @ 1.4k
6. PSU: Cooler Master RS500-PCARA3 xtreme Power + 500W @ 2.8k
7. Monitor: BenQ G2020HD 20" LCD Monitor @ 6.5k
8.PowerColor HD4850 1GB GDDR3 @ 7.2k
Total 32.2k.
Street price is lower.
Now for graphics card, I suggest you to wait for few days for the DX 11 card price to be decreased. I think at December the price for 5750 will be 7k to 8k. Go for that one.
26-11-2009, 02:10 PM
Ditch the psu and go for cm real power series instead of xtreme series.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
26-11-2009, 07:25 PM
Back in black
Total 32.2k.
What vickybat said above is right. Get a CM RealPower 460W or a Corsair VX450.
Intel Core 2 Quad Q8400
ASUS P5Q
Corsair TWIN2X4096-8500C5DF
Corsair CMPSU-450VX
Zotac GTX550Ti
Corsair H80
CMStorm Scout
26-11-2009, 08:58 PM
Crowman
^  Both are worth the 1k or so over the CM Extreme.
27-11-2009, 12:16 AM
Athlon II X4 620
gigabyte 785GM
2 GB Kingston 1333 MHz DDR3 *
Zotac 9800gt 1gb
Gigabyte 460W Superb
finalized this config will be going for it tomorrow
Thanks everyone for the help
27-11-2009, 02:23 AM
Originally Posted by krates
Athlon II X4 620
gigabyte 785GM
Zotac 9800gt 1gb
hi krates,plz post the prices of ur config u actually have to pay....i'm also buying new stuff,(ddr3+athalon x4 620..etc)........where do u live(state.,,etc)
27-11-2009, 04:39 PM
Athlon II X4 620
gigabyte 785GM
Getting the combo for 11,900rs + 400 rs as they are not available in my city
2 GB Kingston 1333 MHz DDR3 = 3k
Zotac 9800gt 1gb = 6.9k
Gigabyte 460W Superb = 2.3k
Gigabyte Cabinet for = 1.2k
27-11-2009, 08:52 PM
Hi Krates
Go for the GTS 250 instead of 9800gt.The former performs better at roughly the same price.Look for either zotac or palit versions.
28-11-2009, 10:18 AM
#19 (permalink)
Back in black
Instead of a 9800GT or a GTS250 I would rather suggest a HD4850 which scales better at higher resolutions.
ASUS P5Q
Corsair CMPSU-450VX
Zotac GTX550Ti
Corsair H80
CMStorm Scout
28-11-2009, 10:43 AM
#20 (permalink)
GTS250 or HD4850? Please tell ...
28-11-2009, 11:54 AM
#21 (permalink)
Crowman
GTS250 512MB is great if playing at resolutions upto 1440x900 maybe even 1680x1050. Above that its 4850. GTS250 512MB is a little better than 4850 1GB at above mentioned resolutions. What resolutions do you want to game at?
28-11-2009, 09:50 PM
#22 (permalink)
I will change my monitor next month...
right now I will play them at 1024x768
and from next month I will buy a monitor under 7k and then I will get to know what resolutions...
I want to know isn't the 9800GT good as the above mentioned cards are bit much higher then 9800GT
28-11-2009, 10:28 PM
#23 (permalink)
Crowman
Its good, but you are being ripped off. Palit GTS250 512MB should be for 7.1k and 9800GT should be 6k or less.
