Old 02-11-2009, 10:55 PM   #1 (permalink)
Question Firewire card driver not working
I have a newly assembled PC with XP Pro SP2. I added a 1394 firewire card. XP detects the card and installs the drivers but the drivers indicate error status (yellow exclamation). This card has worked fine in another system also running XP Pro SP2. What could be the problem? How can i sort this out?
The only difference i can figure out is that in the first PC, XP was installed with the firewire card in place right from start. In the new PC, I forgot to put in the firewire card. I fixed the card only after all the updates were completed.
Thanks for any help.
Lets share our lives and enrich them.
ramborums is offline
Old 02-11-2009, 11:08 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Firewire card driver not working
Where you got the driver from. Get it from the AMD/ATI sites. Official sites. What motherboard you have..?
asingh is offline
Old 03-11-2009, 07:30 PM   #3 (permalink)
Used the drivers built in in WinXP. didnt have any driver with the card. The mother board is Gigabyte G31.
I slipped on specifying the driver status in Device manager .. It says Device could not start. Code 10.
I couldnt find any drivers for firewire in AMD or ATI sites. Any leads?
Thanks for your response.
Ramesh
Old 03-11-2009, 08:26 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Ramesh
What is the EXACT name of your card.
asingh is offline
Old 03-11-2009, 09:40 PM   #5 (permalink)
if you are referring to the make, it is VIA. I dont see any other name on it. The number on the chip is VT6307. Hope this helps.
Old 03-11-2009, 09:55 PM   #6 (permalink)
Super Moderator
asingh's Avatar
You should get it here.
http://www.via.com.tw/en/index.jsp
asingh is offline
Old 03-11-2009, 11:09 PM   #7 (permalink)
i had already checked the via site. all it says there is that no driver is required for this card / chip. and there are so many threads on various sites on the same problem of 1394 driver in XP SP2. Cant believe there are no XP systems with firewire cards in them!
Old 03-11-2009, 11:41 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Install your motherboard drivers once again.
Just put in the disc, and run the installer. It will patch the missing ones. Re-start when ever prompted.
asingh is offline
Old 04-11-2009, 12:04 AM   #9 (permalink)
the firewire is on a PCI card, not on the motherboard. would it still be relevant to reinstall the motherboard drivers?
Tks
Old 04-11-2009, 09:56 AM   #10 (permalink)
Super Moderator
asingh's Avatar
^^Yea..it would be. I read about it..and that seemed to be an issue, at times. Though this might not fix your problem. But just re-install over the existent ones, no harm will come to the system. If anything is missing or corrupt, the new install will fix it. Else it will skip all ready installed stuff...!
asingh is offline
Help me restart pbm aravind.gslv QnA (read only) 1 06-05-2008 01:30 AM
NVIDIA 171.06 Linux Display Driver Cyrus_the_virus Open Source 2 12-03-2008 09:35 AM
Toshiba Laptops Pricelist - January 2008 anuvb101 Hardware Q&A 1 23-01-2008 06:22 PM
using onboard video after installing graphics card vish786 Graphic cards 8 15-06-2007 06:08 PM
My Queries regarding Tv-Tuner Card. Needs Advice from you. Yoda QnA (read only) 12 26-01-2005 12:06 AM
- by bhaskar
