Old 02-11-2009, 10:37 PM   #1 (permalink)
Default LAPTOP Fan kaput... or?
Hello guys!
I own a compaq presario c301TU ( 1.6Ghz, 1.25 Gb ram, 60Gb ). been about 3 years since i bought it. Now what happened yesterday was that while working, suddenly the laptop switched off. All random and abrupt!
Then i switched it on after like 10 mins and it worked but again in 15 mins, it went off. So i let it be and then switched on after 3 hours, only to be suggested that the fan may have stopped working. So i checked and realised that i cant hear anything. But the deal is i am not too sure of how it sounded earlier, so i have no basis to compare.
so i downloaded speedfan. and saw that when i switch on my laptop the temps are around 50 C and then go upto 72 C. From there, it may go upto 85 if i watch a movie, or stay at 72-73 when idling and only downloading. The peak has been 93 C after which i hurriedly switched it off.
Also, now i dont dare to do any resource intensive stuff, so i try and contain it to sub 80 levels. Till that happens, i can work (mails, IM etc). Laptop hasnt gone off again since then but that maybe due to the fact that i am careful and constantly monitoring the temps.
i called up HP CC. They flahed my BIOS (upgraded to the latest) thinking it would fix it. But even now it doesnt seem to be working. (i cant hear the damn fan!)
So anything here would be greatly appreciated. I want to try everything i can. Calling all the tech gurus out there, HELP ME!
Thank you!
wishmaster.dj is offline
Old 02-11-2009, 11:08 PM   #2 (permalink)
Cool G5's Avatar
Default Re: LAPTOP Fan kaput... or?
Clean it up. Fan may have gone kaput or be clogged with dust.
Cool G5 is offline
Old 02-11-2009, 11:21 PM   #3 (permalink)
can you tell me how to go about it?
Also, in case the fan is gone, how much should i expect it to hurt me monetarily?
Old 03-11-2009, 12:59 AM   #4 (permalink)
Cool G5's Avatar
Take it to a technician.
Don't worry it won't cut your pocket deep.
Cool G5 is offline
Old 03-11-2009, 11:01 AM   #5 (permalink)
the proper authorised guy or some nehru place quack? what would you suggest?
Old 03-11-2009, 11:13 AM   #6 (permalink)
Super Moderator
asingh's Avatar
1. Open it yourself and check : If you have done stuff like this before.
2. Official service center.
3. NP Quack.
Try 1 and 2, 3 if both fail..!
asingh is offline
Laptop Fan Problem ???? satyamy Hardware Q&A 1 26-05-2008 07:47 PM
Acer Aspire 4720 Z Laptop Review FilledVoid Reviews 8 11-01-2008 05:06 PM
Cases: How to Avoid Overheating Gigacore Tutorials 3 20-04-2007 01:33 PM
A sub-30k Laptop ...? con_tester Hardware Q&A 9 30-12-2005 03:04 PM
- by bhaskar
