Old 01-11-2009, 07:45 PM   #1 (permalink)
Default which SMPS ?
If I go for Athlon II X2 240 & Gigabyte 780 mb, then plz tell me which smps ?
will it work with inbuilt smps bundled with Zebronics Bijli ?
vishal is offline
Old 01-11-2009, 08:03 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: which SMPS ?
Whats ur budget???
I think Zebronics Platinum 500W or CM Extreme Power + 500W is more than enough for u......(Even if u add a powerfull gfx card)
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 01-11-2009, 08:08 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@Vishal, the onboard one will work if you are not having graphics card. look for a decent 500W PSUs from Gigabyte or Cooler Master if you have 2.5k budget.
desiibond is offline
Old 01-11-2009, 08:21 PM   #4 (permalink)
very low on budget.......will zebronics ( bundled) one give stable performace......?
vishal is offline
Old 01-11-2009, 08:33 PM   #5 (permalink)
Simply a DIGITian
If u r not adding graphics card I think its ok.....The shud be no prblm.......
Old 01-11-2009, 08:39 PM   #6 (permalink)
Thnks Everyone...... if not the Zebronics one.....which one is better?( low budget)
vishal is offline
Old 01-11-2009, 08:39 PM   #7 (permalink)
Crowman
Krow's Avatar
I still would not suggest Zebby. But, if budget is low, then one can't help it, I suppose...
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 01-11-2009, 08:51 PM   #8 (permalink)
Simply a DIGITian
The inbuilt SMPPS will do if u dont add graphics card.
But if u r really on a tight budget thn Zebronics Platinum 500W is what I recommend.
But i can up ur budget a little then CM Extreme Power+ 500W
Old 01-11-2009, 08:51 PM   #9 (permalink)
if not Zebby thn which one ?
vishal is offline
Old 01-11-2009, 08:58 PM   #10 (permalink)
Simply a DIGITian
Dude what's ur budget??
Thr is many..
Like Tagan is best.
Tagan 500W - 3.5k (approx)
or as I said CM Extreme Power + 500W - 3k(approx)
Corsair VX450W - 4k (approx)
Old 01-11-2009, 09:01 PM   #11 (permalink)
budget ....max Rs. 2000-2200 for smps
vishal is offline
Old 01-11-2009, 09:15 PM   #12 (permalink)
Crowman
Krow's Avatar
^Gigabyte 460W Superb @ 2.2k.
Krow is offline
Old 01-11-2009, 09:22 PM   #13 (permalink)
Smile Re: which SMPS ?
Thnx.............
vishal is offline
Old 01-11-2009, 09:33 PM   #14 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Go with Krow's suggestion.
Old 01-11-2009, 09:45 PM   #15 (permalink)
Ok... one more query i have a pc with VIP gold smps...AMD 7750 , Gigabtye MA78GM-S2HP sometimes hangs, restarts arround 1hr......is this due to smps ? bijli one will work with this config ? or Gigabyte 460 W ?
vishal is offline
Old 01-11-2009, 09:54 PM   #16 (permalink)
Simply a DIGITian
The default SMPS with bijli is enough for this...
Old 02-11-2009, 11:29 AM   #17 (permalink)
thnx
so the problem with AMD 7750 + Gigabtye MA78GM-S2HP is bcoz of VIP gold smps ?
vishal is offline
SMPS and burnt computer nvidia Hardware Q&A 2 21-06-2007 11:00 PM
Help me in selecting SMPS N@LiM Hardware Q&A 5 07-02-2007 02:52 PM
Quantum SMPS ?? vaibhav92 Hardware Q&A 3 04-09-2006 07:29 PM
Counsel for an SMPS siriusb Hardware Q&A 27 10-07-2006 03:29 PM
new smps magnet QnA (read only) 5 09-02-2005 11:23 PM
- by bhaskar
