Old 28-10-2009, 10:46 PM   #1 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
Default Need help to OC Q6600
I need some guideline or help to OC my Q6600,can you help me???
Here is my pc configuration:-
Intel C2Q600
Asus P5K Premium WIFI-AP
4x1GB DDR2 667MHz
Seagate Baracuda 7200.12 500GB HDD
ATI R3650 (ordered ATI HD5850)
Cooler Master Hyper 212 Plus
Cooler Master Xtreme 500W
sxyadii is offline
Old 28-10-2009, 10:56 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Need help to OC Q600
It is the Q6600 if I am not mistaken and not the Q600. Check on CPU-Z if you like.
asigh and topgear both are intel users and they can help you best.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 28-10-2009, 10:58 PM   #3 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
It is Intel C2 Quad Q6600...
sxyadii is offline
Old 28-10-2009, 10:59 PM   #4 (permalink)
Crowman
Krow's Avatar
CPU Overclock List & Discussion Thread
^^Refer to asigh's chart there. BTW, I hope you are not on stock cooler. If it is not stock cooler, then go ahead with it.
Krow is offline
Old 28-10-2009, 11:09 PM   #5 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
No, I have changed to CM Hyper 212 Plus Cooler.... it reduced my system temp 51C to 34-36C.
sxyadii is offline
Old 28-10-2009, 11:17 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Follow that chart. If you run into issues, we can help.
Monitor the temperature:
1. Everest Lavalyst in taskbar -- all 4 cores.
2. RealTEMP or OCCT for stress.
Best of luck.
Posted again:
Also..where you stay in Delhi..?
asingh is offline
Old 28-10-2009, 11:27 PM   #7 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
Yes,I m from Delhi
sxyadii is offline
Old 28-10-2009, 11:30 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Originally Posted by sxyadii View Post
Yes,I m from Delhi
Yea, which part..?
asingh is offline
Old 28-10-2009, 11:31 PM   #9 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
^ Uttam Nagar..
sxyadii is offline
Old 29-10-2009, 09:45 AM   #10 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
It is my first time in overclocking.. I changed my CPU core speed from 2402MHz to 2527Mhz..:-P
sxyadii is offline
OC Issues sam9s Hardware Q&A 173 13-10-2008 03:31 PM
XFX 8800GTS 320MB oc benches... hellgate Hardware Q&A 7 30-04-2008 08:53 PM
How to OC E4500? New Hardware Q&A 19 30-01-2008 09:02 AM
- by bhaskar
