Old 27-10-2009, 09:57 AM   #1 (permalink)
Default What is Bifpc.exe virus
Hi I Am Abhishek
I am facing a problem with my system
I am having norton Antivirus 2005 which shows My System is infected with bifpc.exe virus whuch is in My User Account ( Document And Settings/ Abhishek )
When ever I start My System windows shows an message can not find specified file etc..
second problem is My System is not starting . when I start my PC monitors light blinks CPU also runs but nothing happens. When I disconnect Display cable monitor turn on and when I connect it goes off.
This problem is very old . first time when it occured my hardware guy cleaned the Chip. Next time he told me to change SMPS I changed it twice. Recently I change system's Motherboard and CPU Fan And RAM but after 1/ 2 months same problem is occuring . CPU fan is of normal quality around Rs 250/-
What should I do. Is it Motherboard , Is is electricity connection or SMPS . Monitor is working.
My System Configuration
Intel P4 3.00 Ghz ( 3 years Old)
Gigabyte G 31
RAM 1 X 1 GB DDR2
LG DVD writer and DVD combo
ramdas is offline
Old 29-10-2009, 09:37 AM   #2 (permalink)
CA50's Avatar
Default Re: What is Bifpc.exe virus
Nortor05 is definitely very old. Install avast 4.8 n update its database. Then run a full system scan better to scan in boot time mode. Regarding da 2nd prob wait n watch for other members to submit their post.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Got infected with win32/dzan.a virus !! sosmuthu Software Q&A 11 18-11-2007 11:56 AM
Tut On How To Detect Virus In Your Computer Without Antivirus Software krates Tutorials 4 06-05-2007 02:30 AM
New Browser created darkknight Technology News 28 17-04-2007 08:27 PM
Do We Need Anti Virus for Symbian OS 9 Devices? alsiladka Technology News 4 26-03-2007 10:13 PM
- by bhaskar
