Old 27-10-2009, 07:18 AM   #1 (permalink)
bajaj151's Avatar
Default Ram Problem in Win 7
I installed Win 7 with 1gb ram and yesterday I added 512mb more..
Now, I am facing problems like Automatic Restart and freq hangs.
Both rams are of same frequency.
What may be the problem ???
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Old 27-10-2009, 07:34 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Ram Problem in Win 7
^^ Try the single 512MB DIMM alone...?
Also keep the pager file 1.5 x total RAM. Keep the pager file on the partition which does not have the OS.
asingh is offline
Old 27-10-2009, 08:25 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@bajaj151. hmm. can you post more detail like speed of both the sticks and look for error logs in windows.
desiibond is offline
Old 27-10-2009, 10:49 AM   #4 (permalink)
Super Moderator
asingh's Avatar
^^ Why GPU..
He should able to boot into Desktop with 512MB..?
asingh is offline
Old 27-10-2009, 10:54 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
damn. sorry. i mis read his post. correcting it.
Old 27-10-2009, 11:30 AM   #6 (permalink)
bajaj151's Avatar
Both are 400mhz and No error found...
bajaj151 is offline
Old 27-10-2009, 11:37 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
if the OS works fine with 1Gb model, either the second module is faulty or the second ram slot is fault. try different things like test with 1gig stick and then only with 512gig stick and then placing gigs in different ram slots.
btw, what is the model number of you mobo.
Old 27-10-2009, 03:30 PM   #8 (permalink)
bajaj151's Avatar
Slot was faulty..now..everything working fine...
Thanks...
Posted again:
Thanks for all d suggestions...Prob solved...
bajaj151 is offline
Win XP SP-II Installation Problem skghosh44 Hardware Q&A 28 07-02-2008 09:35 PM
RAM problem or Hard Drive?? hearthacker Hardware Q&A 3 28-03-2007 07:43 PM
RAM Problem : Please Help subratabera Hardware Q&A 7 24-09-2006 12:18 PM
RAM problem? tanmoy_rajguru2005 QnA (read only) 11 16-04-2006 12:23 AM
Increasing Ram will solve my problem???? q3_abhi Gamerz 13 28-05-2005 01:39 PM
- by bhaskar
