Old 24-10-2009, 10:36 PM   #1 (permalink)
Default Need Suggestion on TV Tuner Card
Hi everybody,
I'm looking forward to buy a good TV Tuner Card.
-->I'm having Tata Sky Connection. It is having analogue outputs. One Video Output and another RF out (I dunno what it means).
--> PC Config: D930, 945GNT, 2 GB RAM, Windows 7. I've also fitted a 9600 GT in the PCIe16x slot and Creative Fatal1ty Pro in PCI-e slot. I guess there are some PCI slots remaining and one PCI-e (i'm not sure about this)
--> I need to record the TV shows in its maximum possible quality.
I'm thinking of buying a TV tuner card that supports H264 recording. Is there anything like it?
If not can i buy the card separately and use any thrid party software to capture devices?
In whatever case, the quality must be at its highest. Becaue I'm having a 22" monitor and low video resolution really s****!
--> I can push my budget as far as it takes.
--> I don't care about the size of the captured video as far as the video quality is of top notch(though they are not HDTV broadcasts, it should be at its maximum quality).
--> Don't care about its form factor (either External / Internal), as long as it doesn't affect the picture quality. BTW, is there any PQ difference between internal and external cards?
--> I might consider a feature rich card, but then again, if it stands as a hindrnace to deliver good PQ, I might look in for other options.
Can you guys PLEASE help me out?
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
Old 24-10-2009, 11:04 PM   #2 (permalink)
Drifting in DIRT 2
sxyadii's Avatar
Default Re: Need Suggestion on TV Tuner Card
wt is UR budget??
sxyadii is offline
Old 25-10-2009, 01:17 AM   #3 (permalink)
Around 2K to 6K
emmarbee is offline
Old 25-10-2009, 08:34 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
check winfast palmtop TV 2
desiibond is offline
Old 26-10-2009, 05:35 PM   #5 (permalink)
thanks for the info desiibond.
The leadtek site says, the card needs a 3rd party software to encode the videos in h264 format. Are they talking abt PVR softwares? If so, which PVR is good?
emmarbee is offline
Old 26-10-2009, 05:57 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I would say Windows 7 Media center
just check if that device is compatible with win7 media center.
http://www.engadgethd.com/2009/07/27...center-review/
http://gizmodo.com/5095414/10-really...enter-features
afaik, windows 7 media center natively supports H.264.
also, do remember that winfast palmtop tv 1 does not support windows media center and is bit inferiour os specs. I was talking about the second edition of this card. also check in other brands too.
btw, have you considered Tata sky+ or a hardware DVR?
Old 20-11-2009, 06:59 AM   #7 (permalink)
Though there are far better cards in the market, I’d still suggest the WinTV PVR150 MCE which I and all my friends are using since a couple of years, simply because it is plug n’ play with Windows Media Center. It has a Hardware MPEG2 encoder and Windows Media Centre’s scaling to a higher res is just amazing. I get better quality on my comp than on my TV. The best part is it comes with the Media center remote and all this costs just under Rs. 1900 currently. I bought it for Rs.1400 two years ago.
otpsurvive is offline
- by bhaskar
