Old 24-10-2009, 12:59 AM   #1 (permalink)
ayushman9's Avatar
Red face Which Brand for HD Raedon 4670 ?
I finally settled for HD raedon 4600 series but i was baffled by the price differences the brands were showing for same product
Here what the local retailers (In Raipur ) Offer
XFX Raedon 4650 (512 mb) -- Rs 4.2k/-
Sapphire Rae 4670 (1GB) -- Rs 4.9k/-
Asus rae 4670 (1 GB ) -- Rs 5.8k/-
Now i am literally confused as there is so much difference between similar products and in some case even for same specifications the difference is massive . Should i go for sapphire ? What extra features Does Asus give for so much price range ?
Maybe the retailer was bluffing but i need confirmation
There is No Dark & Light side of Force . There always has been,always will be & always has been,One & Only Ayushman
ayushman9 is offline
Old 24-10-2009, 01:51 AM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: Which Brand for HD Raedon 4670 ?
Get the sapphire one, the XFX one is 4650, so its much weaker, on the other hand 4670 can't really use 1GB memory, so 512MB is fine.
Get Sapphire, good brand, good warranty and moderate price, and the dealer gave descent price, its supposed to cost about 4.7k, so its more or less OK.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Old 24-10-2009, 02:05 AM   #3 (permalink)
ayushman9's Avatar
I don't understand ,what do you mean by 4670 can't use 1 GB memory
Old 24-10-2009, 02:19 AM   #4 (permalink)
tkin's Avatar
Say you have a pentium 3 and 4GB memory, is it of any use? No, its a similar analogy, the 4670 has small no of shaders, so the amount of data it can analyze per sec will fit on 512mb memory easily, so if you have 1GB memeory on GPU, 512mb is going to waste as it can't use all that memory, but high end GPUs can, a GTX285 has enough processing power to crunch a large amount of data which will not fit on 512mb, it needs a larger amount of memory(1GB). So a 1GB 4670 is nothing but a marketing gimmick. GPU speed and power depends on no of shaders mainly, other stuff like memory requirements depend on it.
PS- This is mere simplified analogy but it works like that, I don't know this stuff in that much detail.
tkin is offline
Old 24-10-2009, 07:15 AM   #5 (permalink)
The Sorcerer's Avatar
Sapphire- comes with the good bundle. I am not too sure but maybe you get pc mark vantage with it.
Hardware BBQ
The Sorcerer is online now
Old 24-10-2009, 12:01 PM   #6 (permalink)
ayushman9's Avatar
I think you are right ,actually i saw the price difference was just 200 rupees difference ,i should have smell the Rat
Old 24-10-2009, 02:33 PM   #7 (permalink)
Crowman
Krow's Avatar
^Lol, make that human. Rats are much better than humies.
Anyway on topic: Sapphire is a good brand for ATI cards in general. If you can find MSI, then it is also good, so is Palit. Just look for warranty. Some brands may give more warranty and some have good after sales service. AFAIK, XFX has ASService by Rashi Peripherals, which does not have a good reputation for service at all.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 24-10-2009, 02:39 PM   #8 (permalink)
Palit stopped making cards for ati. I found TIM which is usually used on low profile cards on mid end cards- perhaps that's why people complain about xfx heating up after using it for some time. Sapphire's warranty is honoured by aditya infotech. Sapphire from other country can get their warranty honoured here via aditya infotech as well- all one need is a copy of an email from sapphire tech support authorising the RMA and maybe a small fee for shipping to U.S.
Hardware BBQ
Old 24-10-2009, 03:11 PM   #9 (permalink)
tkin's Avatar
Didn't know that, well then, sapphires the only way to go for AMD.
tkin is offline
- by bhaskar
