Old 20-10-2009, 04:04 PM   #1 (permalink)
Arsenal Fan
arsenalfan001's Avatar
Exclamation Need an External dvd-writer
The dvd-writer of my laptop has given up on me. And I am looking for an external dvd-writer. But I dont have much of an idea about the external dvd-writers. Please help me choosing one and tell me a good shop in Pune for the same. thank you
arsenalfan001 is offline
Old 22-10-2009, 07:06 PM   #2 (permalink)
nns
Default Re: Need an External dvd-writer
You can try the shops at the end of East Street near Burger King
nns is offline
Old 23-10-2009, 08:33 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
my friend bought Buffalo dvd station external writer for some 3.5k and it was pretty good.
desiibond is offline
Old 23-10-2009, 06:45 PM   #4 (permalink)
Point Blanc
if you are thinking of bulky external burner better go for casing + a good burner. I have been using my external burner same way its good deal and will cost you less than 2K with best burn speeds @16x upto 22x. will need external power adapter which will come with casing. Any branded external burner using power adaptor will also cost more than 3.5K.
If not you are thinking of slim burners you can get LG/Sony slim burners which go with 8x burn speed. LG costs somewhere 3.5K and Sony somewhere 4.5K. running on using USB power
Also I had seen LG external burners which need a power adapter in Croma in @2K. Havent checked recently in Croma, but it was the best deal you can think for branded external burners
acewin is offline
Old 24-10-2009, 02:49 PM   #5 (permalink)
Arsenal Fan
thanks to all of you. and special thanks for acewin for clearing things for me. LG external burner seem to me a good option.
thank you
- by bhaskar
