I want to connect my Nokia 2700c with my PC.
Nokia have not provided any data or usb cable....
So I need a bluetooth adapter for my PC.
Pls suggest me a good VFM usb adapter(brand or model name) with price.
And also suggest me 2GB good VFM microsd card with price.
I heard that some microsd card comes with usb adapter so I can connect it to PC.
Is that true ?
Thank you.....
what's your budget. Branded ones like Belkin bluetooth dongle are a bit costly and the el-cheapo ones are available for as low as 200 bucks and maybe 150 bucks.
Sandisc 2Gb microSD should cost less than 450 bucks now. never heard of microsd with usb adapter. you may get from some local or chinese **** but nothing from branded afaik.
Though I don't want to spend much still how much for Branded ones ?
Are those much better than cheap ones and cheap ones mean the Chinese onse or they are from other brands ?
not the chinese ones. I meant tech-com and other stuff. and some unknown companies also exist but you never know if they will work with OSes like linux/vista/w7. so, it's better to stick to known brands.
