what will be the maximum page file size for a machine with 2gb ram
i know,,it may be a lame question but i need to optimise my page file size for getting my compi a bit faster,,,my current config is pentium d 2.8, 2gb ram, Ati IGP x200 ,xp pro service pack 2,and seagate 160gb hdd...so what will be my page file size for getting the maximum juice out of this old rig,,shall i enter the minimum and maxmum values the same so as to boost performance,,,eagerly waiting to hear from u,,cheers,,prat
Nokia X6
Nokia E5
Dell Inspiron 15"(Dun fu**in really care bout the suffix,does my geeky chores,that's it)
a 500 GB (priceless,every bits of it) music repo.
Gold Flake,OMR
Re: what will be the maximum page file size for a machine with 2gb ram
^ +1 and yes keep the minimum and maximum values same, it helps by preventing OS from changing the pagefile size dynamically. Also, as you have 2 hdd, keep the pagefile on different disk from system disk.
AMD Athlon 4200(939) | Asus A8n32sli-delux(resting in service center) | 2x1GB DDR 400MHz Transcend | nVidia XFX 6800gs XXXed and [new Ati HD 4850] | Samsung CRT 17" | Corsair 620HX
