Old 15-10-2009, 11:30 PM   #1 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Default Home theater for both TV & PC
I am looking out for a home theatre in the sub-20k range for my TV. Can I use it to listen to my 5 channel AV media in the HT system? IS it possible that I use the HTS for both PC & TV & what should I look for?
A vendor has prescribed me the Sony DAV DZ390. It sounded ok. But will it really play my 5.1 media in 5.1 style, each speaker giving individual sounds? What should I do to integrate both TV & PC in the speaker set.
Any suggestions as to how to go about? I 'm actually a 0 in electronics/electricals
Help me out here, guyz.
koolbluez is offline
Old 16-10-2009, 06:10 AM   #2 (permalink)
Default Re: Home theater for both TV & PC
Try looking @ logitec or altec lancing home theater systems...'
If u can increased ur budget 5k more then there is onkyo and yamaha systems which rocks...'
Arnab boss is offline
Old 16-10-2009, 07:45 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Onkyo HT-S3200
desiibond is offline
Old 18-10-2009, 09:04 AM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
i heard the onkyo 3200 but was not that impressed as much as the 5205. maybe because of the rooms setting & the 3200's passive subwoofer.
philips & sony too have got some configs in the sub-20k range... namely philips hts 3371 & sony DAV DZ390. i like philips all-round playability.. plays almost everything. sony DAV DZ390k is said to be the best in the sub-20k. What about these models?
Help me decide, guyz? Is it really worth to go for a Onkyo HTS3200 @ 5k plus without a DVD/Bluray player than a Sony DAV DZ390k?
Old 18-10-2009, 09:17 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
In that case, why not buy Onkyo's amplifier and philips/sony speakers?
Old 18-10-2009, 12:56 PM   #6 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
ppl help me decide if it's really worth to go for a Onkyo HTS3200 @ 25k & without a DVD/Bluray player than a Sony DAV DZ390k @ 19.5k? ppl who heard both please advice.
Old 18-10-2009, 01:08 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@koolbluez, it's ears that need to do the talking. Take a demo of both with couple of videos and decide which one your ears like
Old 18-10-2009, 01:18 PM   #8 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
tried it, but the rooms they used for both changed. i was able to hear some sounds better in the Sony set. but all vouch for onkyo!
I wanted to connect with my PC too. Onkyo has a better system to give me max utility... for sony with pc it's just 5.1 sound, no dolby etc.. for onkyo with pc better suport to dobly/dts...
also i can justify that i can connect any player to onkyo... but sony has inbuild amp.. so i've to stay on it if i want amplifier too (cant upgrade/change player without compromising on amp)
I want another ear to share the onkyo/sony experience.
Old 18-10-2009, 02:11 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Check the next model S5200:
http://www.us.onkyo.com/model.cfm?m=...ss=Systems&p=i
7.1 channel
Total 1200W with a Powerfull 10-inch 290W Powered Subwoofer
If you want an idea of where Onkyo’s home theater packages are heading, the HT-S5200 is well worth checking out.Like previous Onkyo 7.1-channel receiver/speaker packages, the HT-S5200 delivers reassuringly hefty amounts of power and all-round performance. And in line with other recent offerings, it’s also perfectly suited for high-definition entertainment in the home: 1080p video takes center stage from sources such as Blu-ray Disc, DVD, HD broadcasting, and gaming. The emphasis is still on Onkyo’s audio prowess, so the HT-S5200 is equipped with three groundbreaking Audyssey technologies that will give you the edge in terms of surround sound.It also features some exciting innovations from Onkyo: a dedicated port that connects the iPod via the Dock for the iPod and DSP modes specifically designed for gaming.
Old 18-10-2009, 08:59 PM   #10 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
checked it yesterday... cant cough up 10k more now
only option Onkyo HTS3200 @ 25k or Sony DAV DZ390k @ 19.5k
Have to tell if onkyo model is worth the 5k more...
Old 19-10-2009, 09:24 AM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
hmm. when you are getting a massive amp with wide array of connectivity options, yes. it is worth the extra 5k.
- by bhaskar
