Do note I am mentioning this here as prevention is better than cure. Unlike other tech forums I know off, this one seriously need heads up once in a while
This was seemed as an isolated incident as toms' hardware initial engineering samples went bust IIRC, other reviewers complained the same. When the manufacturers gave the final version of the p55 boards from their respected companies, the damage was the time:
http://www.tomshardware.com/reviews/...,2436-15.html\
It was then followed here:
http://www.xtremesystems.org/forums/...52#post4064552
And then anandtech responded:
http://www.anandtech.com/mb/showdoc.aspx?i=3661
Normally we do not worry too much about mishaps during extreme overclocking testing as they are typically caused by factors outside of the supplier’s control. The overriding concern is that we have damaged every motherboard in our possession for the overclocking P55 shootout as well as two very expensive i7/870 processors. These problems are the cause of a single component and are repeatable. As such, we thought we would provide details on current problems and will provide an update once all of the motherboard manufacturers affected have had a chance to properly respond.
As of now from the xs forums, so far DFI have dropped Foxconn on 1156 until further notice however few earlier manufactured units were with foxconn sockets EVGA are using a mixture of TYCO AMP, LOTES and Foxconn. ASUS uses only foxconn Gigabyte uses foxconn- but don't know much if other 2 sockets are used. As of now, till such damages are taken care of, its best if people stall their upgrade plans.
