Old 12-10-2009, 06:27 PM   #1 (permalink)
Exclamation Desktop is not getting switched on
Hi All,
When I am switching on my computer the motherboard led is swithing on my system is npt getting switched on.
System Fan or SMPS fan is not working. I even changed the power cable of my system but of no use.
Please guide on what could have gone wrong.
Regards
Sudhir
Sudhir
kbsudhir is offline
Old 12-10-2009, 09:49 PM   #2 (permalink)
Default Re: Desktop is not getting switched on
SMPS fan not working means most prolly your SMPS is fried.
Are you hearing any bip sounds while boot up?
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 12-10-2009, 10:21 PM   #3 (permalink)
AMD - Aaja Meri Darling
^second that. Most likely SMPS is fried. Do you see any light on the motherboard when you switch on the power ? (most motherboards I think have an onboard LED for power status )
Dont keep trying to switch it on, you may damage everything else (if they aren't damaged) try getting a SMPS from someone and test whether the system boots up using it.
AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
Xeno is offline
Old 13-10-2009, 08:54 AM   #4 (permalink)
Always Fresh!
shri's Avatar
PC wont boot, fans spin for a sec
BE YOURSELF :)
http://everythingoutthere.co.cc
shri is offline
Old 13-10-2009, 11:07 AM   #5 (permalink)
Well if check your motherboard on a friend's PC. If it doesnt work there its your mobo that's the problem. Otherwise your can say SMPS. But better if you post your full config along with brand name.
hell_storm2006 is offline
- by bhaskar
