Old 11-10-2009, 09:43 PM   #1 (permalink)
Question USB not working with Kbd or Mouse
I have assembled a new PC with Gigabyte motherboard. Strangely the mouse and keyboard work only with the front panel USB ports and not the rear USB ports. Other devices like Pendrive, etc work fine with all the ports. Any idea what could be the problem?
Thanks
Ramesh
Lets share our lives and enrich them.
ramborums is offline
Old 12-10-2009, 08:48 AM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: USB not working with Kbd or Mouse
Which motherboard? Do pendrives or other USB based devices work with the rear slots? If not, then try contacting Gigabyte support. Worst case may be that there will be a fault in the rear ports. You will get a replacement for that.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 12-10-2009, 08:51 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Thanks
Ramesh
By default, in gigabyte mobos, USB K/B and Mouse are disabled. You need to go to BIOS and enable them.
Go to BIOS -> Integrated Peripherals and change the settings.
desiibond is offline
Old 12-10-2009, 08:53 AM   #4 (permalink)
Crowman
Krow's Avatar
^Hmmm.. That's new to me.
Krow is offline
Old 12-10-2009, 08:54 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yeah. I faced the same problem and whenever I reset BIOS, I need to change these settings. Donno why
- by bhaskar
