Old 10-10-2009, 01:08 PM   #1 (permalink)
TheHumanBot's Avatar
Default pendrive stucked in RAW format
pendrive transcend 4GB
my pen drive is in RAW format so i cant format it
i tried Control Panel => Admin. Tools => Disk Management
but pen drive is not listed in this list
so any other idea about this
Twitter Handle : /TheHumanBot
TheHumanBot is offline
Old 10-10-2009, 02:15 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: pendrive stucked in RAW format
So ur PenDrive is recognized by Windows?
If yes, try to open it by double clicking, it would ask u to format b4 using...
Format and use.
or,
Right click on it and select FORMAT.
It can never happen that u can't format a RAW partition/USB drive.
A few months ago, my USB drive crashed and showed up directly as RAW...I formatted as NTFS, and it allowed me to.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 10-10-2009, 02:32 PM   #3 (permalink)
Default Re: pendrive stucked in RAW format
Try using a Linux Live CD and then formatting.
ico is offline
Old 10-10-2009, 02:39 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Exclamation Re: pendrive stucked in RAW format
If u r gonna use this solution, remember, through Linux u can't (AFAIK) format that in NTFS, FAT32 or FAT...
rhitwick is offline
Old 10-10-2009, 02:50 PM   #5 (permalink)
We can easily format them in FAT and FAT32.
ico is offline
Old 10-10-2009, 02:52 PM   #6 (permalink)
Democracy is a myth
rhitwick's Avatar
Red face Re: pendrive stucked in RAW format
We can easily format them in FAT or FAT32.
Can we?? but I could not find that option........
rhitwick is offline
Old 10-10-2009, 03:19 PM   #7 (permalink)
^^ You can use Gparted Live disc for formatting pen drives. - http://sourceforge.net/projects/gpar...d-live-stable/
Or you can simply install Gparted in your Linux distro to do so. Here's how Gparted looks:
It can also be done using terminal. - http://sathyasays.com/2007/06/13/for...sing-terminal/
ico is offline
Old 10-10-2009, 03:58 PM   #8 (permalink)
@rhitwick
when i click on format from right click menu nothing shows up...
NO DIALOG APPEAR
@ico
gpart
dude its 100MB download
thanks for your replies still not solved
Old 10-10-2009, 04:15 PM   #9 (permalink)
Well, it is a 100MB download, but it is something one must really have IMHO.
And also tell us about your Pen drive? Company? Model? Capacity?
ico is offline
Old 10-10-2009, 04:17 PM   #10 (permalink)
dont have that much time now
and formatting is kinda urgent
Old 10-10-2009, 04:21 PM   #11 (permalink)
Try this and let us know: HP USB Disk Storage Format Tool http://www.pcworld.com/downloads/fil...scription.html
ico is offline
Old 10-10-2009, 04:35 PM   #12 (permalink)
naah not working its shows checking drive but nothing happen since 10 minutes still processing
Old 10-10-2009, 05:00 PM   #13 (permalink)
Democracy is a myth
rhitwick's Avatar
Try these two links:-
http://www.howtomendit.com/answers.php?id=46383
and
http://www.computing.net/answers/har...lem/51606.html
(if in a hurry start reading from response no. 8)
rhitwick is offline
Old 10-10-2009, 05:19 PM   #14 (permalink)
i already mentioned its not showing up in the list
and utility is not for my pendrive
error please insert data traveler to continue
i was scared so decided try getting a solution from vendor site
and i found it problem solved with this link
http://www.transcendusa.com/Products...recovery_2.asp
- by bhaskar
